Old 11-04-2019, 11:47 AM
RFoot19 RFoot19 is offline
Boat: NXT22
Floor Yellowing
The area that is under my carpeting has developed a slight yellow tinge. Normal washing has not helped remove it. What products to other use to remove this?
Old 11-04-2019, 11:50 AM
John Johnson John Johnson is offline
Boat: 2018 NXT22 Prior 2002 Maristar 230 VRS
I'd be interested to know this as well. Seems it only happens where rubber backing meets the deck. Mine is white.
Old 11-04-2019, 12:02 PM
dh009 dh009 is offline
Boat: Mastercraft, X-30, 2012, 5.7 ILMOR
Sounds like plasticizer migration. I had this happen from a mirror mount on the windshield frame. Left me with a yellowish stain. So far nothing Iíve tried has removed it (goo gone, acetone, ordinary cleaners).
Old 11-04-2019, 01:58 PM
Scampbell18
Posts: n/a
I uses MaryKate On and Off Boat Hull cleaner. This stuff removes anything off your hull with very little effort. I doubt its recommended for the inside of the boat (hydrocloric acid) but i used some sparingly on the floor or my boat and it made it look brand new. I also ran the hose for a long time in the hull to make sure I got all the cleaner out the drain so it wouldnt corrode anything down below.
If i had to do it over again, I wouldve wiped up as much as possible first before rinsing down through the hull. This stuff is magic, but toxic.
Old 11-12-2019, 12:42 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
^Yes, if that or toilet bow, cleaner doesn't take it off, idk.
'06 X2 MCX
