#9481
My brother has a ridgeline and yes he gets flamed from the family for it. For him it works as he doesn’t tow anything and just needs a bed occasionally for Home Depot/Lowe’s runs and hauling other things.
Sent from my iPhone using Tapatalk |
#9482
it shouldnt even require solid state batteries though. i think were at the very early bend in the curve. as you said the next 5-10 years should be really interesting
finding that balance between vehicle cost (driven mostly by powertrain components and "excess" batteries), and charging speed is the main thing. as the battery cost comes down with more EV proliferation itll make more and more sense to carry around several times more battery than you might today, at the same time charging speeds will continue to come down to keep up with "refilling" that excess capacity while over the road. |
#9484
Solid state batteries enables several things simultaneously. The lower heat output means they can be charged much more rapidly. The lighter weight means they cut into the range less. They're also more energy dense, meaning you can have more in less space, or have more space available. They're also much more difficult to catch on fire. We'll see a rapid shift in the next 5 years if solid state batteries achieve scalable manufacturing by the end of the year. If solid state battery tech takes a long time to come out, LFP battery tech should get us to the point of being able to charge 300 miles in 10 minutes in the next 10-15 years. LFP battery tech is relatively immature compared to NCM, due to the fact that Tesla and other battery manufacturers focused heavily on NCM because of the higher energy density. Despite the lower energy density, LFP has some key advantages such as higher theoretical charge rates and cycles before degradation. |
#9485
Annual wash and wax. Top to bottom detail. Can't say I've hated this truck. 3/4 didn't work for travel. I love the bench on the cheap models.
#9486
New work truck.
It’ll tow some ____! Trail boss is what all Chebbies should look like. Not a pavement pounder.
#9487
Old faithful. Compound turbo. Sent from my iPhone using Tapatalk |
#9488
^ Beautiful truck!
Twins ,eh? Details please.
#9489
Nothing too special. I have a 380th momentum I pull with it. Kept the stock turbo to maintain the exhaust brake and put an s480 over it with arp 625 studs. Rest is completely stock. 60hp tow tune from ppei. I have to check the dyno sheet again but it’s 495-500hp/1300ish ftlb at the wheels if I remember Sent from my iPhone using Tapatalk |
#9490
-Aric LONE STAR MASTERBASH 2021 https://www.lonestarmasterbash.com/ 2019 XT22 - Ear Bleeder 2020 Crest 240 SLC Tri Toon |
Thread Tools | |
Display Modes | |
