Old 01-13-2020, 03:17 PM
BeJay1981 BeJay1981 is offline
Boat: 2004 X9
Older ZFT Over-Tower Bimini Build
At 6'3" I'd had enough of the low mounted bimini on the X9. By reusing two of the original factory bows, 4 universal tower clamps, and a few odds and ends I was able to make up a custom over-tower bimini. I reused 3 of the 4 the quick-connect mounting points so it can be opened/closed in no time.
This is more or less a proof of concept as my sewing skills aren't superb...but it works! No flapping when opened and I can walk under it.
Old 01-13-2020, 03:21 PM
lakedrum03's Avatar
lakedrum03 lakedrum03 is offline
Boat: 2003 X-Series MCX
That is so awesome!
I want one!
Being on a boat that's moving through the water, it's so clear. Everything falls into place in terms of what's important and what's not. - James Taylor
Old 01-14-2020, 12:36 AM
gweaver gweaver is offline
Nicely done! If you lengthen the legs on the rear bow, and add some extra material, you can extend the bimini back another foot or so.
I didn't do this, came this way when I bought the boat. It's a two-piece bimini- there's a zipper that connects the front and rear sections, right behind the tow point on the tower. Honestly, I wish it was about 12 inches longer on each end, but as it is, it shades quite a bit of the main cabin area.
G
Old 01-14-2020, 12:39 PM
Boat: 2004 X9
G, Can you resend that picture? It's not showing up.
I'm curious how yours has the back bow. My dilemma was the longer you make the bows, the higher it sticks up past the tower when folded. I tried to make sure it all was pretty even at the top when folded up.
Old 01-15-2020, 12:49 AM
Not sure what's going on with the photo, but here's a direct link.
LINK
As far as the back bow, yes, it will stick up past the tower- on mine, I just remove it when the boat's back on the trailer. Each of the legs attaches to the tower with a screw knob. There are two zippers, one on each side of the tower ball. Then the two straps that go to the back of the tower base legs. I'll admit, it's a bit of a hassle to put on/take off (takes about 5-8 minutes or so, but the extra length and coverage is worth it.
G
Old 01-15-2020, 02:16 PM
Boat: 2004 X9
G, I do like the further extension towards the back. Maybe I'll get some motivation for a rev2 version down the road.
