Old 09-11-2019, 07:46 AM
bcippola bcippola is offline
Boat: 2015 X30
Factory prop on 2015 x30?? Upgrade?
Factory prop on 2015 x30?? Ours is dinged up and thinking of switching to ACME 2305 since we mostly surf and kid wakeboard. Boat is in Ga and we bounce between lake Allatoona and Lake Nottely ( elevation 1800 ft). X30 has stock mastercraft ballast and 750 bags in each rear compartment. Very happy with current wave but want to lower rpms to save engine wear.
Thanks in advance
2015 Mastercraft X30
Old 09-12-2019, 09:29 PM
Maxirat427's Avatar
Maxirat427 Maxirat427 is offline
Boat: '14 X30 6.2L, '96 SkiRay Tournament(sold)
It was an OJ 522 14.75" x 15.5" .170 cup, which turned into a 787 at some point. Same prop either way. I went with an Acme 2061. According to Acme should have picked up low end and top end. Only thing I noticed was it turned a few hundred RPM more at every speed. No noticeable gain out of the hole and topping out at same speed only at 400 RPM more. Sending it to Nettles to have it re-pitched and cupped to a 1593. Keep in mind an OJ 14.75" diameter prop is really only 14.5" so if you go with the Acme 2305 you are actually gaining .5" diameter not .25" like it appears but you will be loosing significant pitch. Your boat will have noticeably better hole shot and mid-range but your top end will suffer and your cruising RPM will go up significantly.
There may be better ways to relax than being on a boat...I just haven't found one yet!
Old 09-13-2019, 07:17 AM
Boat: 2015 X30
Thanks Maxirat427. Guess I will just recondition the existing prop this winter.
