Old 08-12-2019, 10:00 PM
GottaLuvGravity GottaLuvGravity is offline
Boat: X23 2018 6000
X23 surf setup for beginners
Anyone have any good recommendations for a surf setup for the X23 for beginners struggling to get up?
I could care less if the wave is wimpy and they can't drop the rope. I'm just trying to minimize the huge down slope on the back side of the wave that sucks beginners in if they don't get to the outside fast enough.
Old 08-12-2019, 10:31 PM
Coloradodude's Avatar
Coloradodude Coloradodude is offline
Boat: Mastercraft x-15 2009
Put it on mellow. If say they are surfing port side, if possible get them on port side or turn steering wheel hard to the left on the start help them start out in the flat . A thin wakeboard, one that is not so buoyant, say a (skim Board with fins helps also)
Old 08-12-2019, 10:36 PM
SteveO's Avatar
SteveO SteveO is offline
Boat: 2019 XT22
Try mellow and tap on the ballast part of the mode settings and manually override from 100% fill on port and starboard and try 60% ish
2017 NXT22, 2015 NXT20, 2007 X2, 2002 209
Old 08-12-2019, 10:39 PM
SS LS1's Avatar
SS LS1 SS LS1 is offline
Boat: '17 XT20, '13 X2 Gen2, '98 30th Anniv PS190
For beginners I set up custom left and right profiles with no ballast but still using the surf tabs. Makes for a clean wave on the surf side that is not so steep and intimidating to new riders. Also hook your tow rope to the side of the tower arch they are surfing on. Helps get them out in front of the wave when it begins to form much better having the rope on the center tow point.
XT20 5500 GDI Black Mica/Black Topdeck/ Black interior
SOLD - 2013 X2 Pro Pkg, Gen2 Surf
SOLD - 1998 30th Anniversary ProStar 190
SOLD - 1985 Stars and Stripes
Old 08-13-2019, 08:38 AM
jgraham37128 jgraham37128 is offline
Boat: 2016 Mastercraft X23
Increasing the tabs will mellow the wave, also speed up too. I believe my mellow settings are 60, 20, 0. Full ballast at 11.0
Another option is leave settings alone and just don’t fill the ballast.
Old 08-13-2019, 09:06 AM
Mastercraftdave's Avatar
Boat: 2015 X23 SS 6.2L
You need to fill the ballast to create the wave. Put the settings to Mellow.
In order to drop the rope, the wave needs to create the push to keep the board in the pocket.
As mentioned above, speed up so and that will make the wave smaller.
Old 08-13-2019, 01:28 PM
Boat: X23 2018 6000
Thanks everyone for the suggestions so far.
I have tried 0 ballast w/ factory tab settings. It was pretty bad.
I have tried full ballast w/ more tabs and speed. It doesn't solve the startup problem that there is a huge down slope if you end up on the wrong side of the wave.
Putting the rope on the outside of the tower helps but I was hoping for better.
I intend to play with some moderate ballast and tabs together and was wondering whether anyone had done the same and found a favorite.
Old 08-13-2019, 03:12 PM
You need to have the ballast 100% to create the wave an and push, adjust the tabs and the speed to change the wave size.
Sounds like you need to use the factory mellow setting.
Old 08-13-2019, 08:11 PM
mca1710 mca1710 is offline
Boat: 2015 X23
We struggled with people getting over the wash too. I tried to keep the speed low until they could get out of the wash and into the pocket, then increased to full speed.
We also had the rope on the surf side and would also turn to that side to help them out
Sent from my iPhone using Tapatalk Pro
Old 08-13-2019, 09:26 PM
Oh, your talking about starting. I tell everyone as soon as you get up go to the left as quick as you can the long you wait the higher the wave gets.
