Old 07-16-2020, 01:04 AM
Saunders08 Saunders08 is offline
Boat: 2002 X-9
2018 XStar wakeboard setting
I just got a 2018 XStar 50th Anniversary edition. When I put it in advanced wakeboard setting or intermediate setting the boat will not go over 13 mph. Iím at a lake thatís at 5100 foot elevation. Dealer said it could be a prop issue. Anyone have this issue?
Old 07-16-2020, 09:01 AM
badinlake badinlake is offline
Boat: 2019 X-Star
What is your weight distribution? I haven't had an issue that it won't go over 13 at all, but coming out of a turn, if I have fully loaded, I have seen it struggle. 2 things have helped there - first, send more people to the front. Second, deploy the center tab until speed comes up. I'm running at a much lower elevation - and have used both the stock and the ACME 3289.
Side note on probs - I noticed the ACME 3289 is definitely higher speed/lower RPM, but struggles a bit more under heavy loads.
Old 07-16-2020, 09:25 AM
csherbo's Avatar
csherbo csherbo is offline
Boat: 2020 XStar
Are you enabling Triple Tab Auto Launch? Pretty essential if you are running full ballast.
Old 07-16-2020, 12:25 PM
Boat: 2002 X-9
Yes running the triple launch. Didnít change anything on the over all speed. Definitely better getting out of the water.
Old 07-16-2020, 01:00 PM
WakeRider107 WakeRider107 is offline
Boat: boat
I'm confused - so you are getting on plane or not at all even with triple autolaunch?
Old 07-16-2020, 01:04 PM
Boat: 2002 X-9
I’m getting on plane with the triple launch but it won’t get over 13 MPH. Dealer thinks it’s a prop issue because of altitude. Doesn’t really make sense to me how it is fine in all other setting. Maybe because to much ballast weight?
Old 07-16-2020, 01:19 PM
WakePowell WakePowell is offline
Boat: Mastercraft X-Series
Try this. Select wakeboard intermediate and let the ballast fill. Then select drive and disable the speed control. See if you can then get it on plane and to speed. If so, there may be something a miss with your speed control.
Additionally, whenever I have had an issue. I turn the ignition off and then turn the battery off. Let the boat sit for a few minutes then turn on the battery and then the ignition. Often this reboot works.
Old 07-16-2020, 03:26 PM
Boat: 2002 X-9
Thanks I will give this a try!!
Old 08-17-2020, 04:38 PM
Boat: 2019 X-Star
Just a belated follow-up post to this.. I have found w/ a full load of people that the weight distribution, startup speed and using the tabs are all key - or else you can get stuck @ 13MPH and not get up to plane...
First - yes, use the triple launch setting
Second - hit it hard and work to get up to speed fast. Don't bother trying to do a gentle start.
Third - you may need to move some people to the front at start, then move to back when @ plane
Fourth - manually deploying the center tab while trying to come to speed (after auto launch shuts off) can help
and Fifth - this is a new one, I have found the X-Star doesn't like the weight distribution w/ the stadium seating setup when I have a full boat. It also sometimes struggles to get a clean wake w/ stadium seating pulled out. When I say full boat, I had full ballast and 13 adults on the boat.
Old 08-17-2020, 04:44 PM
eecyclone eecyclone is offline
Boat: 2018 XT22
I ran an X-star with full ballast and 11 adults and never had any issues getting on plane. The 6.2 with 2:1 transmission made it feel easy.
What are you triple autolaunch settings? I want to say the side tabs should be at 15-17mph and the center tab at 19-20 mph. If they're retracting too early then they aren't helping you to get up to speed.
'18 XT22 w/5500 & Upgraded Premium Stereo
(Previous- '08 X2 w/MCX)
'16 F150 Platinum Screw 3.5L Eco 4x4
I can help with Klispch Stereo modifications
2020
