Old 07-31-2018, 04:52 PM
AVPdx AVPdx is offline
Boat: 2018 X23, prev 2017 XT20
2018 trailer wheel bearing cap failure
I have towed my 2018 X23 aprox 300 miles since new this spring. Last week on the way home from the lake I noticed lubricant leaking out of the center hub cover on the rear wheel of the trailer. I removed the cap covering the lug nuts and found the cap for the wheel hub that houses the bearings was rolling around loose in the hub cover. All of the bearing lubricant had leaked out. Took off the hub cover on the opposite side and the cap had come loose on that side also, and was leaking lube. Called the dealer and they said not to tow the boat as the bearings could seize up if there is insufficient lube.
The tech came out today to replace the bearing caps and found that the rubber O ring that goes between the cap and hub had failed. All four wheel hubs had broken O rings. He said that he has seen a number of 2018 trailers with this problem as the caps were over tightened at the factory causing the O ring to break. These are the Vortex brand hub kit.
Its worth going and checking the O rings on the hubs if you have a 2018 trailer. If the O ring is cracked or broken then the cap will work itself loose and the lube will leak out. I'm going to buy some spares in case it happens when I'm on a trip.
This is the part- https://trailerpartssource.com/TIE-D...iABEgJZw_D_BwE
Old 07-31-2018, 05:23 PM
uplandbird uplandbird is offline
Boat: 2018 X23 6000GDI - Previous 2014 Gen2 X25 6.0L
When did you take delivery of your 2018?
Old 07-31-2018, 06:53 PM
May 2018. The tech thought the majority of 2018 boat trailers have the Vortex hubs
Old 07-28-2020, 01:23 PM
JulioX2's Avatar
JulioX2 JulioX2 is offline
Boat: XT-22 5.3L 5500GDI
I'm literally just going through the exact same problem. Towed my 2018 XT-22 through the rocky mountains for the first time since I bought it new. My dealership wasn't really helpful when I tried getting some help/advice from them. It's in the shop currently getting fixed.
I'm just wondering if they just replaced your O-rings and caps, or if was something else? Have you had any issues since they fixed it?
Thanks!
Old 07-28-2020, 01:30 PM
Tony84121
Had a similar problem with my 2018; although mine, the rear axle bearings were incorrect. Only found this out when I was bleeding the trailer brakes, and lifted the rear wheel, and noticed considerable play. After working with corporate MC, Corporate shipped 2 replacement hubs/spindles for my dealer to then have installed. Could have been a disaster had I not found the issue!
Old 07-28-2020, 01:52 PM
SurfIowa SurfIowa is offline
Boat: 2018 X23
I had similar issues last summer with X23 trailer. Replaced all hubs and seems to be ok now.
Old 07-28-2020, 02:14 PM
WakePowell WakePowell is offline
Boat: Mastercraft X-Series
I will chime in, my 2018 trailer had the same issue.
Old 07-28-2020, 02:32 PM
edwin edwin is offline
Boat: 2016 X30, 6.2L
Had the same issue with my 2016 trailer. I bought the vortex replacement covers and installed them myself...wasn't worth the time to drag the trailer to the dealer for a 5 minute fix.
Old 07-28-2020, 02:39 PM
WolverineFW WolverineFW is offline
Boat: 2018 Mastercraft XT21
I just had the same issue with my 2018 trailer that I towed for the first time a couple weeks ago.
Sent from my SM-G965W using Tapatalk
Old 07-28-2020, 03:44 PM
eecyclone eecyclone is offline
Boat: 2018 XT22
Almost 7,000 miles of towing my 2018 trailer and I haven't had any issues (knock on wood)
'18 XT22 w/5500 & Upgraded Premium Stereo
(Previous- '08 X2 w/MCX)
'16 F150 Platinum Screw 3.5L Eco 4x4
I can help with Klispch Stereo modifications
2020
