Old 09-10-2019, 04:22 PM
CF-maristar215 CF-maristar215 is offline
Boat: 2010 Maristar 215V
Engine/display screen shutting down intermittently
I have a 2010 maristar 215V with about 175hrs and have been having some issues with the boat shutting down without warning. I can pull 3 skiers and go 30mph or cruise around with no problem. Several times with port and aft ballasts more or less full, while wakesurfing and going about 11mph, the engine will quit, display will beep and shut down. Its done it several times and there is no indicator when it will happen. Sometimes we surf with the same config and nothing will happen. I've reconnected the battery, checked the software for engine faults, etc. but it shows nothing. HELP!! Any thoughts??
Old 09-10-2019, 05:35 PM
Shaun R's Avatar
Shaun R Shaun R is offline
Boat: 2011 X25
Have you checked your kill switch to make sure it’s not the issue? I have a similar setup and accidentally bumped mine the other day and it shut down exactly as you mentioned. It wasn’t hard enough of a bump to knock it off, but it was just enough to shut everything down.
Old 09-11-2019, 02:38 PM
Will double check that. Thanks!
