Old 09-11-2019, 11:37 AM
tryathlete tryathlete is offline
Boat: 2008 Mastercraft 197TT
2008 Prostar 197 platform removal?
Iím hoping to pull the swim platform to redo teak oil. Do I just pull the two pins and hinge the platform upwards to remove?
Old 09-11-2019, 11:44 AM
Ironhorse Ironhorse is offline
Boat: 2008 Mastercraft X14 w/ LY6
If its the same as my X14, you will also have to remove the bolt on each side to remove it. The spacers are a PIA when you put it back on.
Old 09-11-2019, 11:56 AM
John Johnson John Johnson is offline
Boat: 2018 NXT22 Prior 2002 Maristar 230 VRS
I would not remove it. I made that mistake last year and the spacers are indeed a PITA to reinstall. I used a little toothpaste to hold them in place. Better off swinging it down and refinishing it. Tape off a drop cloth to protect your hull.
Old 09-11-2019, 12:26 PM
mcmx2 mcmx2 is offline
Boat: 2005 TT 197 #77
Unless something has changed, the 197 does not have spacers. Just pull the two pins and the platform lifts straight up. Easier with two people, one on each end, but doable with one reaching from the back around the sides of the platform.
2005 197 TT #77 LQ9
Old 09-11-2019, 12:33 PM
tommurtha tommurtha is offline
Boat: Prostar 197 2003
my 2003 197 has the glass platform. I just pull the pins, lift a bit and slide out
Old 09-11-2019, 03:04 PM
mustangtexas's Avatar
mustangtexas mustangtexas is offline
Boat: 2005 MasterCraft Prostar 197 & 1989 190
On the 2005 197 you pull the pins and the platform slides straight out.
Old 09-11-2019, 08:59 PM
I hope mine is the same. Itís teak and has a pretty complex structure compared to my Nautique which slide in from the top and lock with big pins
Old 09-11-2019, 09:19 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
The "spacers" (iirc) are just nylon washers and are, indeed, a pain to get back in place. I'm fairly sure I didn't worry about them all that much when removing my 197 and X14 platforms. Remove the platform and refinish it. Don't keep it on the boat.
Old 09-12-2019, 03:01 PM
fskof's Avatar
fskof fskof is offline
Boat: 2003 Prostar 209 MCX
Originally Posted by tryathlete View Post
I’m hoping to pull the swim platform to redo teak oil. Do I just pull the two pins and hinge the platform upwards to remove?
Can you post a picture of your platform? I have not looked at the newer models but on my boat (2003 prostar 209) you just pull the two pins (one on each side) and slide the teak platform out. To reinstall its easier with two people.
Old 09-12-2019, 11:44 PM
Yah. I will do that when I head out there tomorrow or Saturday
