Old 05-27-2020, 07:36 AM
hardycm's Avatar
hardycm hardycm is offline
Boat: 2011 Prostar 197
Fuse for fuel sender? 2011 PS 197
Hi,
Related to a previous thread, I've determined the issue with my fuel sender seems to be lack of 12 V to the sender. I've looked under the dash and around the engine for breakers / fuses that might be blown but haven't found anything.
Does anyone know if there is a fuse for the sender or have a diagram showing where the 12 V feed comes from so I can try to track down the issue?
Thanks in advance!
Chuck
https://teamtalk.mastercraft.com/sho...d.php?t=104583
Old 09-15-2020, 02:20 PM
hardycm's Avatar
Replying to my own post in case someone has this problem in the future. There is a small bank of fuses hidden under the dash. You need to remove the carpeted piece by your feet (three screws) and remove it. Then will see a small plastic box on the bulkhead which contains 8 fuses (3 Amp & 5 Amp). These supply power to the fuel sender as well as a few other things.
2020
