Old 03-25-2020, 09:32 PM
jgraham37128 jgraham37128 is offline
Boat: 2016 Mastercraft X23
Look for a travel cover. I got mine with the boat and use it from time to time.
Old 03-25-2020, 11:37 PM
brianeissmann brianeissmann is offline
Boat: None yet
Originally Posted by mca1710 View Post
That boat will drink some gas and the tank is small with that engine. The X23 only holds around 50 gallons. We just got an X24 with the 7.4 and it holds 85 gallons. We used a 1/2 tank our first day out.
Itís a great boat but you can watch that gas gauge drop with a lot of surfing or cruising long distances.
Enjoy the boat
Sent from my iPhone using Tapatalk Pro
The gas tank is smaller with the 7.4 compared to the 6.2?? Or just small in general? Advertised is 57 gallons or something but yeah its crazy. Filled it up tonight and rough estimate was about 9gph over the tank. Just getting used to the usage, but its so worth it!!
Boat: None yet
Are you talking about the cover that comes from the factory? I have the over the tower cover for it.
Old 03-26-2020, 08:20 AM
mca1710 mca1710 is offline
Boat: 2015 X23
Gas tank is small in general for that boat. You need a lot of gas to feed that engine.
If you search the pages here you will find someone that added gas tanks in the back where the rear bags go.
Old 03-26-2020, 12:22 PM
Diesel's Avatar
Diesel Diesel is offline
Boat: 95 Prostar 205
Get an Acme on it and it will help with the gas and overall performance.
https://teamtalk.mastercraft.com/sho...d.php?t=100338
05 ProStar 209, Navy Flake, Slate Gray, MCX 1:1 Sold
15 X23 7.4
Old 03-26-2020, 07:47 PM
Boat: None yet
Oh nice! Are you still running the Acme 2841? Make a considerable difference in fuel economy?
Old 03-26-2020, 08:53 PM
duckguy's Avatar
duckguy duckguy is offline
Boat: 2019 X-23, 1983 Stars and Stripes, 1991 Jump Boat
Where did you place your lead?
Old 03-27-2020, 10:11 AM
Diesel's Avatar
Yes the 2841, it transforms the boat. You could even go a little lower on the pitch if you run really heavy with people and weight. 2915 looks interesting, but you might hit the rev limiter at WOT.
Acme also has a series of 15.50 props that might work well. The 2843 and 2919 would probably also be good options.
Call JT at Nettle's props. He has the best prices and service is amazing.
Chris
15 X23 7.4
Old 03-27-2020, 10:04 PM
Boat: None yet
Along each side I did 100lbs under rear bags, 100lbs under the tower and 50lbs up front. Might change it around a little to compensate for the battery weight.
Old 03-28-2020, 04:44 PM
Boat: None yet
Chris
Ill definitely have to look into that thanks! Yeah I don't care about high speed, usually cruise 25-30mph at most. Usually not in a hurry.
2020
