Originally posted by BigBarney
Probably caused by the o-rings expanding when the old rudder shaft came out. Be sure to grease up the end of the rudder shaft, the shaft itself and apply some grease to the inside surface of the rudder port from the bottom and from the top prior to trying to insert the rudder shaft and as you inset and feel some resistance turn the rudder from side to side. You will then hit the same resistance when you get to the 2nd o-ring, after you get past the first one. That's what I had to do to put a new rudder in our '89. Good luck! Keep us informed.
