I have a 2006 197 and am having trouble launching and recovering with trailer due to very gradualy sloped boat ramps. When launching the bow gets caught above the " V " pad and when loading the bow gets caught below the " V " pad. Has anyone experienced this or any suggestions ?
Trouble Launching 197
Originally posted by landscapeI have a 2006 197 and am having trouble launching and recovering with trailer due to very gradualy sloped boat ramps. When launching the bow gets caught above the " V " pad and when loading the bow gets caught below the " V " pad. Has anyone experienced this or any suggestions ?
how far in do you have your trailer?
you may need to go in deeper or find another ramp that is steeper?
I think the only time I have had this issue is when I am too deep with the trailer, but since I have not launched the boat yet this year, I may be remembering incorrectly. I put my trailer (2004 197 single axel) in so that the water is just level with the tops of the fenders, and have no real issues on the various ramps that I normally launch at.
Thats all I can think of.
SteveA positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile
2004 Prostar 197 - Red on White
350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun!
Originally posted by landscapeI have a 2006 197 and am having trouble launching and recovering with trailer due to very gradualy sloped boat ramps. When launching the bow gets caught above the " V " pad and when loading the bow gets caught below the " V " pad. Has anyone experienced this or any suggestions ?KEEP YA TOES UP!!!!!
2004 X9 MCX ALL BLACK
http://www.prwb.net/tallington/index.php?id=12
nice older x-boat at berth in the advertisment above
Originally posted by sizzleri have the same problem........i dont put the trailer in as far....i almost sink it to get all the bunks wet..then pull it up the slipway......
..er..I assume that "slipway" is english (or English) for "boat ramp"..'04 MariStar 230VRS/MCX
Its normal. I for the most part only launch my boat once a year so I am no good at it. When I do, I have to use what I believe is way more power than should be needed to get the boat up to the boat buddy and in doing so usually rub some of the soft boat buddy rubber onto my boat about 12" down from the front eye.
1" of the fenders showing is best for me.
yes sir it is............you still have the kings english over ther dontcha...???
i have to have about 2 1/2 --3" at least of the fenders showing....i then attach the winch and wind it in myself whilst my buddy" helps" on the throttle.......Last edited by sizzler; 04-02-2007, 08:27 AM.KEEP YA TOES UP!!!!!
velcome to da klub!
the pre-dip explained above is probably the best thing you can do for that situation...
since you cannot launch or load the 197 by going deep with the trailer, you may be able to predip deep enough that the boat juuuust begins to become bouyant and then pull forward till the fender tops are out of the water
this wets the bunks on the topsides.
watch that your water intake isn't dragging along the bunkrail tooOriginally posted by TX.X-30 fanSay yes to cheap beer---- no to ethanol.
I agree with the above on wetting the bunks and then pulling up the ramp so that the fenders are just at water level.
There is one ramp I use that is pretty steep so I have to put the fenders about 2 inches below the water line.
I have also found that if you will stay in the center of the boat when loading it helps with keeping the boat centered so you don't end up with the water intake on the bunk.
the first time I load my boat I was to deep and ripped the carpet on the V block and bent the prop on the prop guard. Bad DayJason Kelly
