steering cable grease fitting
  • steering cable grease fitting
    After greasing my rudder and steering yesterday ('89 PS190) I discovered that the Zerk fitting in the cable is missing the check valve ball - greasy mess when I turned the wheel to work in the grease. The fitting is smaller than the other fittings and I can't find the correct size anywhere. It is smaller than 1/8 or 6mm. I sure don't want to replace the cable for a five cent fitting. I could re-tap it to the larger size but would prefer to get the correct one.
    Thanks!
    Beleive it or not !!! It is not missing the the ball in the zert. They do this so too much grease is put in. It is best to put some in and work it back and forth then put a little more and repeat to it starts to come out and your done.
    06 AWSA Approved Towboat
      If you take out the original no-ball zerk and replace it with a ball-zerk then you grease it, the steering will lock up. The ball is left out so the excess grease you put in will be pushed out so the steering will cable will move, but you can learn the hard way and swap it out and see what happens for the giggles of it.
      Charter Member Number 1
      Quote: 2RLAKE,
        they're right.
        I had a fun prank on my lil bro, he was greasing in the rear, so I ran the wheel all the way to the right, and he takes the grease gun off and is standing there on the side and i spin it hard all the way around and
        PFT! sky rocket of grease.
        it was pretty sweet.
          all this time, I thought I had lost my ball too
          WE LIVE IN THE LAND OF THE FREE, BECAUSE OF THE BRAVE
          Team MasterCraft Google Search Engine
            Fill it full of grease then turn the steering full left and right. You will see a fountain of grease come back out. These guys are right. If it had the check valve, it would lock up the steering (grease lock).
            Boatless 'til I get out of school.
              Thanks. No wonder they use a different size.
                Does anyone know what size it is and where I can get one?
                here comes the boss!
                Why do they call it an asteroid when it's outside the hemisphere, but
                call it a hemorrhoid when it's in your butt?
                  Where is the grease fitting on my '03 197?
                    There is a aluminum tube at the end the steering cable that bolts on a bracket on the strut bolts and runs to the tiller arm, a fitting is there and there is be a zerk where the cable bolts to the strut and there is one on the rudder port, for a total of 3. Only the tube zerk doesn't have a ball. There should be a diagram/picture in your owners manual showing the locations.
                      in most boats you have to remove rear seat, anything that covers the tank, and then there is an access under there, or the floor can be unscrewed and removed.
                        ooooops me also, ive been looking out for a new fitting for two years,
                        no joy, always wondered where it could have gone to,
                          ha ha, I think this is going to have to be added to the FAQ.
                            Thanks for all the info in this thread. I had never lubed my steering because I didn't know too. I did it today and if I hadn't read this first, I would not have thought to add grease or even check it. And I would have been puzzled over the fitting also SO THANKS AGAIN FOR SOME GREAT INFO!
                            My drinking team has a skiing problem!!!!
                            1995 Prosport 205
                              So this forum is fantastic and this is exactly my problem I removed the zerk when winterizing trying to find one with the ball and now I have lost it what size Zirk is it that I need to replace it with or where can I get one
                              Working on a 1995 205 pro star
