DIACOM Software can´t communicate with MCX ECM / Help!!
  • DIACOM Software can´t communicate with MCX ECM / Help!!
    Mastercraft X-2 2006 MCX, DIACOM Software with Com Cable.
    I´m not able to get a communication between diacom and ecm. My laptop has windows xp. The COM1 is activated. The settings in the diacom software are set to Comm Port 1. Ignition is on. I chanced the first listing in the ECM Selection List (GM DELCO Mode 1 Master).
    But: No communication.
    Error:
    "Check connections and make sure ignition is on"
    The cable is connected and ignition is on. Any ideas what the problem could be?? I tried everything from several restarts of my laptop, chance the baud rate (default is 9600 bits/sec). I have no idea.
    Please help!
    Boat history
    2019 MC XT23 2018
    2018 MC XT20 2017
    2017 MC XT20 2017
    2016 MC X23 2016
    2015 MC X20 2015
    2014 Malibu VLX 2013
    2013 Malibu VLX 2012
    2012 MC X2 2006
    2011 MC X2 2006
    2010 MC X-Star 40th Anniversary
    2009 MC X-Star 40th Anniversary
    2008 MC X2 2008
    2007 MC X2 2006
    2006 MC X2 2006
    2005 MC X2 2005
    No oen on here except a TECH guy will be able to help
    We purchases a NEW laptop last week and Mr Gates NEW CRAP (VISTA)
    gave us all fits. NO DIACOM for a week. Ended up purchasing a special cable and consulting DIACOM quite a bit. SERIAL 2 USB cable was recognized and now works
    You may want to get ahold of Ian or Martin in the UK...they will help
    [email protected]
    www.BAYAREAWATERSPORTS.com
    (813) 996-BAWS (2297)
      Just to clarify...this is DIACOM Marine software, yes? Latest version? For MEFI-5? And you are using the CAN network adapter?
      '04 MariStar 230VRS/MCX
        Diacom Marine 1.5.0 with Can Network adapter.
        Boat history
        2019 MC XT23 2018
        2018 MC XT20 2017
        2017 MC XT20 2017
        2016 MC X23 2016
        2015 MC X20 2015
        2012 MC X2 2006
        2011 MC X2 2006
        2008 MC X2 2008
        2007 MC X2 2006
        2006 MC X2 2006
        2005 MC X2 2005
          You are a few versions behind on your software. Diacom is now running on version 2.03. Go to the following website and download the newest software:
          This will bring you up to the latest software. You would still have to update your USB cable to be able to use Diacom with any of the 2008 model engines with MEFI 5B controller but yours should work with your MEFI 5.
          We tell dealers to check this Diacom update site regularly as whenever changes to the Diacom software are made they are posted there. The updates on the website are free but there is a cost involbed in updating the cable to work with the 2008 models.
          Engine Nut
          Engine Nut
          Indmar Marine Engines
          Power to the Sport
            It may be that you have something in your particular computer that is tying up COM1 during boot and won't let it go. Mouse drivers are notorious for that, even in XP. When Windows boots, if it thinks there's a serial mouse attached, it assigns a mouse driver to COM1. The other possibility is that XP is misreading just what it is that's attached to the COM port and thinks it's a mouse (or something) instead of your EFI adapter. If you haven't already tried it, make sure the adapter is not plugged into the COM port during boot
            If all else fails and you're sure your hardware and software is functional, one ploy is adding /fastdetect:com1 to your boot.ini file, assuming you're comfortable with registry modifications.
              Might also be that the ECM is shot and there will be no com.
              (if there was a problem prior to hooking up Diacom)
              New England WaterSports http://www.newatersports.com
                If you are using com1 RS232 port you will need to match the setting exactly. I would doubt 9600 baud is right. If you can use USB you will be much better off.
