Hi guys, looking for ideas/solutions to fix the throttle panel. I need to find a secure way to attach it to the side. It was a poor design in my opinion. For a while I had it attached by only one bolt but that eventually gave way. The tricky part is it's really hard to reach behind and get to the bolt locations. Maybe someone has a trick to it? I'm open to other suggestions. TIA.
Fixing throttle panel 2001 prostar 209
Looks very similar to the construction on my 205V. I reattached the bolts with a good epoxy after roughening the surfaces and removed the drivers seat to allow the panel to swing out at the base. This allows more room for your arm/hand to reach the bolts from the back side. Not terribly easy but it works. Push in pins like they use on automotive panels might work as well.
Originally posted by 01star View PostHi guys, looking for ideas/solutions to fix the throttle panel. I need to find a secure way to attach it to the side. It was a poor design in my opinion. For a while I had it attached by only one bolt but that eventually gave way. The tricky part is it's really hard to reach behind and get to the bolt locations. Maybe someone has a trick to it? I'm open to other suggestions. TIA.
.Last edited by waterlogged882; 01-04-2022, 10:00 PM.
Best thing I ever did was attach plastic blocks behind the fiber glass and got rid of the nuts and bolts that were impossible to reach. After the blocks were in place I drove some stainless steel wood screws into the plastic board to hold the panel in place. That panel needs to be removed periodically to grease the throttle assembly
Check this thread out. Permanent fix that looks like it could have come from the factory.
https://teamtalk.mastercraft.com/for...s-pics?t=47739
Originally posted by prostar205 View PostCheck this thread out. Permanent fix that looks like it could have come from the factory.
https://teamtalk.mastercraft.com/for...s-pics?t=477392000 Prostar 205V
Originally posted by dpb185 View Post
Do you still have any of those ? I don't have the holes in my panel but that doesn't look difficult to add them.2002, X30, L-18, Red Metal Flake (the possessed boat)
