Hope all is well everyone. So I recently purchased my first boat this past July. First time boat owner. I'm hooked. Love it. I have posted pictures of it in prior threads.
Anyways... the previous owner pulled the engine, had it bored .30 over, new pistons, rings and cam. The rebuild has about 40 hours on it. Just before the winterizing process, I heard some lifter/rocker arm noise and realized he installed another flat tappet cam with solid lifters... so a re-torque of the rocker arms is common after a rebuild. The issue I have is, after all that work of rebuilding the bottom end, he kept it a solid motor and also reinstalled the stock heads, intake and carb. The bottom end is new, with a bigger cam, yet the top end isn't able to breathe anymore than a stock 351. I'm thinking about converting it to a roller motor, along with high performance heads, new intake and carb. If I decide to do this work... what would I see for performance gains? Acceleration? Top speed gain, etc? I would assume it would be about a 30-40hp increase. Would all of this time and money be worth it? I used to be a Ford technician, so the labor would be free. I know what all this would mean in a car as far as gains, but never owning a boat before, I'm not sure what to expect on the water.
Any and all recommendations are appreciated. Thanks.
