The '09 Prostar I bought a couple weeks ago came with the binding blaster ($545 MSRP option) but the pump and nozzle were both inoperable and the tubing was nasty. I located all of the OEM parts and thought I would share. On a scale of 1-10 difficulty this would be a 2 if you wanted to add it.
The tank is Mastercraft part 556217 $113 at MCPartsDepot. You could also use just about any plastic coolant recovery tank.
The original model pump has been updated by Jabsco a couple times. The current model is Jabsco ParMax 1+ Model 42630-3512-3C which I found at Overtons on sale for $56.
The nozzle is CEJN 232. $27 at MCSDirect.com
To connect the nozzle to the tubing I used a 3/8" hose barb to 1/4 NPT swivel connector. $11 at MCSDirect.Com
Tubing is about 6' of 3/8" ID vinyl tubing at your local hardware store, about $1 per foot.
My boat came with a switch, but any toggle switch will work. At some point MC started prewiring everything so I'd be surprised if most boats from the 2000's and later didn't already have all the wiring pulled.
Here it is installed and put together. Total about $213 plus shipping and and an hour of work if you have all your tools handy. Can't wait to try it out in a couple months!
