ProStar 190 Winter Projects
  • ProStar 190 Winter Projects
    Been a busy winter! Wrapped up a few projects on the '09 PS 190. This might be my favorite boat I've ever had.
    Two-outlet Heatercraft heater. Super easy to install in a closed bow, and the toe kick already has the 3" hole cut in.
Name:	2022-02-27 17.50.32.jpg
ID:	2699689 Click image for larger version
Name:	2022-02-27 17.49.39.jpg
ID:	2699686 Click image for larger version
Name:	2022-02-27 17.50.02.jpg
    ProMariner onboard charger. Might put a receptacle in.
Name:	2022-02-27 17.50.45.jpg
    Put the stereo on its own switch (instead of the ignition switch) and updated the other switches to new Contura V.
Name:	2022-01-19 06.11.27.jpg
ID:	2699693 Click image for larger version
Name:	2022-02-27 17.51.08.jpg
    Replaced non-working parts on the shower and Lube Blaster.
    Not pictured: polished and waxed above rubrail, replaced gas springs in glove box and observer seat, JBL bluetooth module, Groco engine flush kit, trailer rachet tie downs, and mounted fire extinguisher (safety first!).
    Apparently I have a leaking oil bath hub on the trailer, the swim platform needs some love, and wife wants a bimini top, but otherwise we are ready for spring!
Name:	2022-01-23 16.59.23.jpg
ID:	2699690 Click image for larger version
Name:	2022-01-23 16.59.33.jpg
    1991 Prostar 190
    2018 SeaDoo RXP-X300
    Lake James, NC
    pics aren't working..
      Which engine does it have?
      Previous Boat- 1983 Stars and Stripes
        Beautiful boat!
        2001 Prostar 209
          The MCX.
          Took it for a spin today to check on things. All good, ready to go!
          1991 Prostar 190
          Lake James, NC
            Originally posted by T-Rex View Post
            Apparently I have a leaking oil bath hub on the trailer...
            Pulled tire off today and the oil bath cap was barely tight. Unscrewed it by hand with no effort. Drained oil, refilled, torqued to spec and no leaks so far. Let's hope that's all it was!
            1991 Prostar 190
            Lake James, NC
              The MCX.
              I bet you can throw it around pretty good
