I am replacing my Prestolite with a Pertronix ( 93 190 351) Since the cap sits a bit higher than the Prestolite will my plug wires reach ok?
Pertronix Distributor
Originally posted by dbatteiger View PostI am replacing my Prestolite with a Pertronix ( 93 190 351) Since the cap sits a bit higher than the Prestolite will my plug wires reach ok?
Overall I think you are looking for a general consensus...Yes...
Thank you Waterlogged I was hoping you would see this. The wires I have are a couple years old. I change them often for lack of anything else to do. Right now there is a set of PCM 7mm from skidim. I have had those blue ones and they seemed longer. Tell me this, The PCM 7mm Skidim sells and those blue ones, they aren't solid core correct? Pertronix guy told me to never use solid core. Al
Originally posted by dbatteiger View PostThank you Waterlogged I was hoping you would see this. The wires I have are a couple years old. I change them often for lack of anything else to do. Right now there is a set of PCM 7mm from skidim. I have had those blue ones and they seemed longer. Tell me this, The PCM 7mm Skidim sells and those blue ones, they aren't solid core correct? Pertronix guy told me to never use solid core. Al
The Pertronix guy told you correctly.
I am hoping it is reliable. I bought the coil too. I have read that people that didn't use the coil have had no trouble. Did you use the coil to match?
Also, my last wires came from Indmar, for the 351w. The length is plenty long enough for the pertronix distributor but unlike the blue ones from skidim they are not so long that they flop around on the floorLink here
Your OEM coil was likely a 10kV output. The new Flamethrower II (0.6 ohm epoxy-filled) puts out a rated 40kV. A much higher voltage (obviously) for a more responsive ignition in all eight cylinders. The spiral wound wires have less resistance than the solid core...thus better results. Again, all of these things work together to make a better deliverable in performance.
Since you did not ask I will further comment to break your budget; 1) Arco 70200 starter, 2) new Holley 4160 600cfm marine carburetor, and 3) for general sustainment; the DB Electrical ADR0334 alternator (primarily for battery charging with a dual setup).
It all comes together. You will think you have an EI setup.
Yes Sir, I use the FT-II coil.
Originally posted by d2jp View Post
Not speaking for waterlogged, but I switched to the Pertronix distributor and the Ignitor II coil. It's not hype, the extra juice from the Ignitor II is what you need.
The other thing I did this winter was have Tommy Nation at Teak world make me a new swim deck. Its as beautiful as new furniture. I hate to put it in the water. The cool thing is he had the original contract with Mastercraft to make their swim decks in 1993. He had the jig that is an Exact, not kind of close but Exact duplicate. Of course it was 600 bucks but its gorgeous.
