08 X1 Fuel sender unit needed
  • 08 X1 Fuel sender unit needed
    Hey all, I am in need of replacing my sender and can't find one for sale. Current model is Moeller with a 8 1/8 long shaft. Maybe there is one that supersedes this model, or is an equivalents replacement. Any help is much appreciated. .
    We have them for sale, use our boat part finder to find the correct one for your boat.
    Water skis, Wakeboards, Wake Surf Boards, Boat Parts, Life Jackets, Life Vests, Boat Accessories, Boat Trailer Parts
    WaterSkis.com - Boat Part Look Up Tool
    MidwestWaterSports.com
    (Previously known as Midwest MasterCraft)
      I did check the url, but the one that shows up is with two wires, and mine has 3.
        This should work. https://www.greatlakesskipper.com/mo...t-sending-unit
          There will be two set screws that you were just one for when it’s full and one for when it’s empty. You’ll need a micro flathead
            I replaced mine 2 years ago and used Centroid products. They were easy to work with, [email protected]. 386-423-3574.
            good luck!
              There are 3 wires in the photo - Red, Black, and White...
                You are probably already aware that due to the Medallion gauge system, you can't use the widely available 2 wire sensors used in a analog gauge system. You need to get one specifically compatible with Medallion and that means either of the two suggested by other posts in this thread.
                  thank you all for the info!
                    Originally posted by gwozhog View Post
                    I ended up buying this one, coz of the price, all is the same but shy of 1/4 inch shorter. we will see, I will take the boat out in the next few weeks and test it , then report back.
