Team,
I am hoping to get some ideas on a second bilge pump that doesn’t require a second portal through the hull.
I have a 99 Maristar 210 VRS, no ballast, so only one bilge portal on the starboard side.
When we ride down the lake, water will build up under the engine and sometimes get into the back port side compartment. I was thinking of putting another bilge pump in the stern and running the tubing alongside the steering cable to the same portal. I don’t want to pump water back into the other bilge area, so I figured I would elevate the two hoses (similar to a dishwasher hose) right before it goes through the hull.
1- Do you think I could just splice into the existing wiring to run both pumps?
2-Will the run from the back of the boat to the front of the boat be too much for one of the standard tsunami style pumps?
3- is this a dumb idea in general?
4- Any suggestions on a “Y adapter” to combine the bilge tubing? Did they happen to make anything like that with a check valve so it can’t follow in reverse?
Thanks for any advice!
