Removing Swim Platform- 2014 X25
  • Removing Swim Platform- 2014 X25
    ​Need a little insight on removing the swim platform for storing my X25 I just bought in my garage. I saw the pins on each bracket that you pull out. Is the only thing to do after removing those is to pull it straight off the back or does it fold up? The SurfGen tabs seem to be in the way of any flipping up. Thanks in advance!
    Pic of the "new to me" boat Click image for larger version
    You need to pull the pins on the on the Surf tabs, drop them down, remove the pins on the platform, then lift up on the platform near the stern and it will fold down. Click image for larger version
ID:	2704202 Click image for larger version
      Awesome. Thanks!
        Beware of the black plastic spacers on each side of where the Lenco actuators pins connect to the tab. They are easy to loose and they are important to be there. They also sink if you ever need to pull the pins while the boat is in the water.
          Thanks! I did this for the first time yesterday in my driveway and saw them fall off. Caught them and put them back with the pin
