Originally posted by Ramp-N-Clamp
View Post
1997 prostar cold start issues
Ok so I changed out the fuel filter and engine temp sensor. I still have it apart and noticed the fuel pressure regulator could/should be replaced since I have it apart. I searched multiple threads about this and found one answer, a 2002 dodge 2500 regulator will work. Has anyone else replaced their in tank fuel pressure regulator? If so, what would be the correct one?
Leave a comment:
Originally posted by 88 PS190 View Post
Dont replace it just check voltage on the purple wire.......
- Likes 1
Leave a comment:
Originally posted by linzandscott View PostAppreciate all the replies. I’ll start going through all electrical parts cleaning up connections and putting dielectric grease on things and I am going to replace kill switch (cheapest replacement part). I’ll post back what the results are.
I have a spare kill switch I would never replace it with out checking if working.
on your boat key on not cranking fuel pump should go bzzzzt and prime. If you pull the kill switch it should not go bzzzzt.
if when the kill switch is on it goes bzzzt you do not need to replace your kill switch.
- Likes 1
Leave a comment:
Leave a comment:
Like the others have said, you need to figure out whether you are having a fuel issue or a spark issue when it won't start. It is usually easier to check for a fuel problem. After cranking the engine (when it won't start) pull a spark plug. If the plug is wet with fuel, you know you are getting fuel and the problem is spark. If the plug is dry, the answer is not so conclusive. You could have either a fuel pump pressure issue, or a timing control issue that is not telling the fuel injector to spray fuel.
Common electrical issues that could cause this are the lanyard switch and the fuel pump electrical connector.
- Likes 1
Leave a comment:
Mine was a phantom for a year until I took the distributor apart,it had two tiny cracks in it,like ps190 I have every spare part on hand.
- Likes 1
Leave a comment:
Originally posted by linzandscott View PostI’m almost leaning towards the ignition control module. I’m going to take it apart and clean all the contacts and see what happens. Has anyone had to replace theirs before?
That said... throwing parts at problems like this is going to cost you money and time you need to sort of work through things incrementally by being critical. IF you don't have fuel what can cause that problem, IF you don't have spark what can cause that problem. What checks can you do for each of those parts before buying it and putting it on?
Hell I have a spare fuel pump, rotor, cap, set of injectors, plugs, wires, coil, pick up coil, fuel water separator. I even have a kill switch, ignition switch, starter, and a spare pylon.
But I have all of those because I've been running these boats for years.
- Likes 1
Leave a comment:
Leave a comment:
Beauty of a TBI boat is that you can pull the spark arrestor and crank it and just watch to see if its squirting fuel that's pretty hard to do on the MPI boats.
So if its squirting fuel you have a spark issue if its not you have a fuel issue. It is possible to have both.
Neither should have a condition where they don't want to crank, both can not want to fire.
- Likes 1
Leave a comment:
Intermittent problems are hard to diagnose when it only shows up once in a while. It needs fuel and spark to run, so the next time it happens remove the flame arrestor and see if the injectors are spraying gas when it's cranking. My 95 doesn't have a port to check the fuel pressure. You can either use a timing light or a spark tester to check for spark, you just have to keep them in the boat at all times and wait for it to happen again.
- Likes 1
Leave a comment:
I had a similar problem in my 94 prostar,it turned out the relucter wheel in the distributer was cracked,put in a new distributer and never had another problem.
- Likes 1
Leave a comment:
When I turn the key the starter turns the motor over just as it should. I can hear the fuel pump prime it just will not fire. One time it sat there for 30 mins then started up, one time I trailered it back home (5 miles) and it fired right up. Yesterday like I said above, pulled out of water and it cranked. We went to Smith mountain lake last year used it all day for 3 days. One morning it would start but 30 mins later I turned the key and fired up. It’s like there’s no rhyme or reason to the madness.
Leave a comment:
Leave a comment:
