Cooler Seat Gas Strut X23
  • Cooler Seat Gas Strut X23
    My cooler seat gas strut isn't keeping the seat up anymore. Does anyone know what size this strut is so I can order another one? My boat is at the lake and not close to me at this point.
    2016 Mastercraft X23
    There should be a set of numbers on the strut that show the extended length and pressure in Lbs or you can measure the extended length in inches. If you google this or look on eBay. or Amazon you should see a number of replacement options. I replaced most of mine last fall. Replacement is very easy if you slide off the locking tab with a flat screwdriver. Of course the dealer can probably get these for $$.
      10mm 15” 60# from Amazon
      https://www.amazon.com/Nylon-Lift-Su...ve%2C61&sr=1-1
