I got it direct from MC back in 2006 so it must be the 178. I did not have to change out my rudder port. I think (it's been a long time since I did this) my rudder port has 4 bolts attaching it to the hull. I could check next time I'm at the boat.
Rudder Upgrade - 2003 X2 (205V)
Originally posted by prostar205 View PostI got it direct from MC back in 2006 so it must be the 178. I did not have to change out my rudder port. I think (it's been a long time since I did this) my rudder port has 4 bolts attaching it to the hull. I could check next time I'm at the boat.¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View Post
I suspect if you did it back in 06 it was the OJ-made 162. Were you able to remove the rudder without interference from the trailer's prop guard?2002, X30, L-18, Red Metal Flake (the possessed boat)
A bit more clarifying information from the MC FB group. Take it for what it's worth, but this came from a MC dealer parts manager with 23 years experience:
200178 is the original 2003 X2 rudder (see my pic below).
TPH's picture above of "200178" is actually a redesigned rudder compatible with 2003 X2/205V, but it's actually part# 200178a.
Furthermore and again from the same parts manager, OJ's 162 was never actually "designed" or "designated" for the 205V hull, but as other members have noted, it was a successful upgrade that did not require a rudder port swap.
He also added that part# 200176 is a larger rudder (larger than 200178) that was used on 2010-2011 X1's (same hull).
Also important to note that I was also told by waterskis.com that there is a 90% chance of having to change the rudder port when moving to the 200178 rudder. Not due to shaft diameter, but due to shaft length and the position of the cotter pin hole. The new rudder shaft is longer. Still waiting on confirmation if this is the case with part# 200176, but I suspect it is.
Hopefully more to come.
¡Viva 205V!
2003 X2 MCX
Originally posted by lakedrum03 View PostBruce - just an idea. If the shaft is longer than you could cut it down and machine the key way longer. You could find a machinist friend or cut the key way in with a chisel and file. One may take longer than the other.
¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View PostPoint of clarification: the shaft length on the 178 is shorter than the stock rudder shaft. Thus the potential need to swap the rudder port.
Well the saga continues. Shot a couple pics of my rudder port over to Eric at OJ and he didn't think the rudder port was theirs. That means the bushing that is available isn't an option.
I then emailed skidim and they don't offer any rudder port seal kits for 2003. So I'm at a bit of a loss here. Where do I go to get a seal kit for this rudder port? Really don't want to have to swap ports.
¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View PostWell the saga continues. Shot a couple pics of my rudder port over to Eric at OJ and he didn't think the rudder port was theirs. That means the bushing that is available isn't an option.
Originally posted by gwozhog View Post
This is the seal used for your rudder port. Its held in by a snap ring.
https://skidim.com/shaft-seal-only-1-1-8in.html¡Viva 205V!
2003 X2 MCX
