Where to find OEM prop specs?
  • Where to find OEM prop specs?
    I'm trying to source the OEM prop spec for my 2001 Prostar EVO.
    It looks like 01' is a split year for the prostar as I see old hull and new hull styles both listed as so. My prop has a few dings and instead of repair, I'd like to replace and keep the old one as a backup.
    I like the current 4 blade as it can cruise as relatively low speeds and planes really easy with no weight, and can hold a plane easily with 1k pounds in it. When I get home I'll post up the current prop specs.
    Any advice is appreciated. thanks.
    Mastercraft’s website has most, if not all, of the old owners manuals on it. They typically have the props listed in them. Attached is from the 2001 manual.
      Thank you Skram. Looks like I need a 14x18LC as my boat has the LTR with the 1.5:1 Hurth.
      Why does the 209/X9 with the same engine/trans run a 14x20 and all the other models with that package run a 14x18?
      Thanks
