The owner's manual for my new-to-me 2007 X45 says "On boat models equipped with a ballast system, a three-position switch will allow for the filling or emptying of the ballast tanks and/or bags. It is important to be aware that the engine must operate at 1500 RPM during the fill and empty processes. Failure to do so can result in malfunction or permanent damage to the ballast pumps that force the water through the system."
I used the boat for the first time this weekend before reading this warning so hopefully no damage was done! That said I don't fully understand the directions for the fill and drain processes. Is the engine supposed to be at 1500 RPM in neutral or while in motion? Can the RPMs be higher than 1500 RPM, i.e. filling while surfing?
Also, I plan to add piggyback tanks to create a better surf wake/wave, and I came across this note - "2007 MasterCraft boats have 6 minute timer modules which will need to be swapped with the 20 Minute MasterCraft Timer Modules to ensure the added ballast bags will both fill and drain when integrated into the factory system." I assume the '20 Minute MasterCraft Timer Modules' can be purchased from MasterCraft, but I am wondering if the pump(s) should only be run for a maximum of ~6min at a time so they don't overheat? There must be a reason that MC wanted the pump(s) to time-off after 6mins.
