I plan on upgrading my 2006 X - 45 stereo. The stereo that came with it is the stock JL system with 2 speakers in the bow, 2 in the main cabin area, a 10 inch free air sub and 4 JL tower speakers. All of this is run off of a single JL e6450 amplifier.
The questions I have are these:
I for sure want more sub. Is the sub a little lacking because of it's nature or does it need more power? I looked up the specs on the amp and it is only getting 150 Watts or so. That seems pretty weak for most any sub. JL's website says that this sub can manage 250 Watts RMS. They have it bridged to channels 5 and 6 on the amp. I wonder if I will be satisfied with the same sub, but with more power or should I swap out both. I could also keep the sub and add a second sub...but I am not sure where to put it - where would you put another sub? I had a single JL 12 inch 12W3 in my previous boat and that was enough for me, so I am not a complete bass head, but I do like to feel a chest thump once in a while.
The interior speakers are probably adequate, but are run from the amplifier in parallel and the specs on the amp was 75 Watts at 2 Ohm, so at best the speakers are getting 37.5 Watts each RMS. .
The tower speakers are also very solid, but I am coming from an HLCD setup (NVS Tyrants) and so these seem a little inadequate. I have my own ideas for that...so we will see what happens.
So stereo gurus, how have you upgraded things? Where do I put another sub, I am not sure a 12 inch sub will fit in the current spot behind the driver. Or do I find a more powerful 10 inch sub?
