Pulled a major Dumas this weekend and between my step-dad and I, we managed to hook up the battery backwards in my PS 205- 350 TBI. 30 seconds with < 10volts of charge. Cant imagine the shear anger and colorful language display.
Anyway, here is where I am at:
gauges work, fuel pump cycles,(this indicates some function of ECM) pumps and motor turns over.
No spark...juice to coil, juice from coil to ignition module(IM); however no juice from coil to dist. cap... supposedly the IM processes juice from coil, communicates w/ECM to ultimately control ignition firing- IM-ECM-coil-distributor...solid state wiring set-up???
I am hoping IM took the toll and saved ECM???
no breakers tripped- :2 of the 3 fuses off ECM have juice to fuse, one has no power- this is powered up when engine is running??? (lost hear) did not follow dead fuse back. This is all when key is "on"
Please no name calling- what an idiot...confused:
thanks for the help...
