Ive heard a lot of good things about the HD amps, never used one though.
Amp Cooling
Years ago when I was cool and had a system in my car, I added a very simple fan to a 4 channel Crutchfield amp (made by precision power IIRC). Anyway, I got a hold of a 12 volt flat based fan (kinda like the 3-4" ones used on old desktop computers) and screwed it to the end of the amp. I drilled holes in the metal amp case where the fan mounted. I think there was enough air gaps around the rest of the amp that it sucked air in from multiple spots (i.e. fuse block, RCA connections, etc). This was enough to fix the overheating problem I was having after running for a while. I had it on a separate switch w/LED on dash to look cool, but in reality, it could be connected to the amp turnon lead to make it easier, then it always runs. I know this cooled the internals rather than the fins, but still did the job.
You may not want to drill in the side of your amp though, mine was a few years old. Just wanted to give another low cost option that worked for me.
Originally posted by btriantos View PostThis JL G1700 is Class D...I hope there is an improvement!
However, since you're upgrading the sub next year, I'd go with the better Slash series amps by JL. The 250/1 slash amp is only about 20 bucks more expensive and you'd be getting a much more solid amp.Last edited by mpabreo; 06-24-2009, 02:34 PM.2020 XStar
2018 G23
2014 XStar
2009 X45
Originally posted by mpabreo View PostThe G1700 will be an improvement from using the stock setup (2 channels off the M6600) which gives the sub 150w rms @ 4ohm. The G1700 will give you 250w rms at 4ohm.
Originally posted by btriantos View PostWhat is the spec difference between the two that is compelling? I got the G1700 for $275.00, which I thought was a good deal. I did not see the 750/1 any cheaper than $599. The budget's a bit tight this year.2020 XStar
2018 G23
2014 XStar
2009 X45
fwiw, i've had 3 subs in 3 years with 4 different amps on 2 different boats. in my opinion you won't notice a whole lot of difference going from 150-250W with the same sub and box. it's not going to blow you away or anything. i didn't really notice a big improvement until this past winter when i upgraded to 600W and i would still want a bit more if i had the coin to completely redo it and upgrade my alternator. i guess my point is, if it were me, i'd save my money and do it right so you're not disappointed and feeling like you need to upgrade again. depends on what you're after i guess too though.¡Viva 205V!
2003 X2 MCX
Originally posted by brucemac View Postfwiw, i've had 3 subs in 3 years with 4 different amps on 2 different boats. in my opinion you won't notice a whole lot of difference going from 150-250W with the same sub and box. it's not going to blow you away or anything. i didn't really notice a big improvement until this past winter when i upgraded to 600W and i would still want a bit more if i had the coin to completely redo it and upgrade my alternator. i guess my point is, if it were me, i'd save my money and do it right so you're not disappointed and feeling like you need to upgrade again. depends on what you're after i guess too though.2003 197 tt- sold
2006 xstar- sold
2012 x-30
Power = Sound.... I remember some audio guru telling me years ago something like..., for every 3db gain above 110-120db or so, you have to double the power to get it.2020 XStar
2018 G23
2014 XStar
2009 X45
you guys are definately having me second guess this. My approach was going to be to get the amp, (G1700 - supposed to deliver 350w at 4 ohms), and see how that goes. I do not have very high expectations, but it should sound slightly better than the amp it's currently connected to at full gain.(stock JL 6 channel). Next season, I was planning on building a custom enclosure for the stock sub, possibly firing it downward in the same location, and have it completely sealed, and not ported (JL recommended this in a 2cf box). I am expecting a much bigger difference on this set up. I already have the Infinity Basslink in the storage locker, and it sounds great. I like clean tight bass, and hate booming, just for the sake of booming. The sub should exhance and round out the sound completely without being too overbearing.(IMO). With that said, am I still off to a bad start? I have built my own enclosures for my vehicles in the past, and follow acoustic guidlines, gut feel, and my ear to make tweaks. I love listening to music loud, but it has to be clean, and not muddy or boomy. That gives me a headache! On your sub upgrades, have you increased to 12's? Where did you locate? How many watts are you pumping to it? What is the RMS rating of the sub?
Originally posted by Eagle Lake Rebel View PostRunning 4 amps in my '07 X30 without overheat pbls. When running, I'll open the port bow backrest for a nice cool 95 to 100 degree gulp of Mississippi air. Two of my amps have built in fans which help a lot. You can mount 3 amps on the side wall if you get a bit creative. I'll try to get a photo to you on how they are mounted, but that may take a few days.
