96 PS 190 275 TBI.Started the season with a rough idle after reaching operating temp. Over the course of two months read every post i could find,(thanks to all especially JimN and EngineNut) Checked for trouble codes,base timing, fuel pressure, compression, spray pattern, etc. Checked all engine sensors as per Indmars instuctions. Condition eventually gets worse were the engine would stall and be hard to start,(engine straining to crank). Go to the local dealer while on vacation he scans the engine and finds the timing at full advance after it stalls. There way backed up with work to go any further so I'm back on the phone Indmar.They tell me it's either the ignition module or the ECM. Put in ignition module, no change. Bypass the computer so the timing is controled by the ignition module still no change. I'm pretty stumped. Engine starts and runs fine otherwise and has plenty of power. Condition will rear it's ugly head ONLY after being at operating temp. for at least 15-20 min.
Sorry for the long post guys. Any input would be really appreciated.
