13.7 X 17.5 or 13.7 X 19.5 for X-30?
  • 13.7 X 17.5 or 13.7 X 19.5 for X-30?
    I know that I am supposed to ask Eric at OJ this question, but it doesn't seem to be good form to go directly to him given that the props in question are used ones for sale in the marketplace. That being said, if he would like to opine...
    I'm looking for a 2nd prop that would be a good primary for big lake (Mead/Powell) use. My current spare is a 13.7 X 15.5 that came with the boat and it just stinks for any purpose on my boat. I have the LY6 engine.
    Has anyone used one of these sizes on an X-30 or MS230 at elevations between 1300 and 3600 ft?
    Thanks,
    dreddy
    P.S. The 13.7 X 15.5 is for sale. If it is the right size for your application, it is basically brand new. Send me a PM.
    He's answered others question regarding used props in the past and I would feel he would treat you any differently.
    Charter Member Number 1
    Quote: 2RLAKE,
      13 7 X 17 5 or 13 7 X 19 5 for X 30
      I believe there is an option to have a edit icon next to the pdf, print and email icons for articles but i cant seem to find where you can choose this option?
      Also with articles I want a second user to be ableto log in and then have access to create new articles and edit old ones, but again I cant seem to get a login area up on the front page to allow this.
      Any help is appreciated
      Regards
      _______________________________________
      Website I developed for canadian pay day loan company.
        If I had to choose between the two sizes I would suggest the 13.7 X 17.5. Neither are a really good fit though. What size are you currently running? Feel free to give me a call if you have any other questions.
        Eric @ OJ PROPS - 800-359-9730
        Thanks,
        dreddy
        Eric Johnson
        Johnson Propeller Co., Inc
        [email protected]
        ojprops.com
        800-359-9730
        sigpic
          Currently I have a 14.25 X 14 on it. It seems to work fairly well for the higher elevation lakes around here (4,000'-6,000') Should I have something different for that application as well?
            The 14.25 X 14 should work OK, most 6.0's will run the 14.25 X 14.5. For the lower elevation you might look at the 14.75 X 15.5, the new "stock" prop from the factory for the 6.0.
            Eric Johnson
            [email protected]
            ojprops.com
            800-359-9730
            sigpic
              Eric -
              I have a 13.7 x 17 XMP prop for my '02 X-30 with the L-18 engine. Is that the correct prop for use on a lake at sea level (0-500 feet above sea level)?
                The 13.7 X 17 would be a good standard prop for a MCX motor. What is the main use of your boat?
                Eric Johnson
                [email protected]
                ojprops.com
                800-359-9730
                sigpic
                  Eric - If your question was refering to my post above, my boat has the L-18 motor (8.1L). My main purpose is surfing with some wakeboarding and general cruising around. I have the stock 14 x 18 SS prop as a backup. I also have the FAE exhaust installed which probably cuts down a little on my top end.
                    I built the 14.75 X 17.5 for the 8.1 powered wakeboats. I would think both the 13.7 X 17 and 14 X 18, basicly the same prop, would not be enough prop, pitch and diameter, for that motor.
                    Eric Johnson
                    [email protected]
                    ojprops.com
                    800-359-9730
                    sigpic
                      Would running the 13.7 x 17 cause bogging down under load (2,000 lb ballast and 5 people in the boat) when wakeboarding? If so, would the 14.75 x 17.5 prop help out? I am not interested in top speed at all. My lake (Lake Washington) gets so choppy during the summer that I really can't go more than 25 mph before the boat starts to porpoise and knock us all around.
                        The 14.75 X 17.5 will be a better all around prop. The larger diameter will help with acceleration problem.
                        Eric Johnson
                        [email protected]
                        ojprops.com
                        800-359-9730
                        sigpic
                          Uhhhhh I'm thinking you forgot the "n't" on the wouldn't
                          Lots of power is good, more is better, too much is just right.
                          '91 prostar 190
                            Typing faster than my mind can work!
