Hello MC enthuriasts
Here some notes from my Project: Additional Ballast System X45.
Special thanks to Brian & Carly from Mastercraft Charlotte ([email protected])
And Jason from Wakemakers.com ([email protected]) for supporting me even on an other continent.
I try to be specific as possible to make it easy for you to do it on your own ... please dont blame me if not every detail is provided. Dont hurt yourself, pay attention to safy, dont overload the boat.
History:
Last year I equipped my X2 with the Fly High Pro X Series Mastercraft X-2 Additional Ballast System:
http://www.wakemakers.com/fly-high-mastercraft-x2-wakeboard-ballast-system.html
This worked fine so far (if you want to do this - order at least 14 ft more hose), but the manually switching of the "3 way valves" was not 100% sofisticated.
So with my new X45 2010 I wanted to improve this.
I decided to set up the add. Ballast System completly independent from the factory system.
Both should work (fill an drain) at the same time to be quicker and without moving to valves or whatever - simply turn switches ... same as with the factory system.
So I needed some parts (see list below this post)
Lets start
Pumps:
I placed the addional ballast puppys for the rear sacks behind the rear cover of the boot (left and right next to the engine). The X45 has enough space there and it is easy to fix with screws onto the outer side of "sepeartor walls" to the engine.
The ballast puppy for the front sacks I placed next to the gear box on the STBD side (just remove the rear seat cushions and you have good access).
My local MC Dealer build in an additional dual waterintale (throu the hull/bottom, next to the gear box port side) - also easy to access (for open and closing and mounting the hoses) when the rear seat cushions are removed.
I connected the 2 rear ballast puppys with this additional dual waterintake.
The front ballast puppy I connect via a Hose Barb Tee fitting to the original single Waterintake.
Q: Why add. Waterintake?
A: to avoid bottleneck for fill and drain
Q: Why not for front sacks?
A. Usually not filled so much / often ...
Plumbing:
See Picture. It is more or less self explaining. For the overflows my MC Dealer also put in 3 orig. Thru Hull Fittings. I connected the sacks via 1" Non-Return Check Valve Fittings to Hull Fittings.
Q: Why additional Thru Hull Fittings and not connecting to the ones from the factory system with a Tee Fitting?
A: Avoid Bottleneck when Sacks and Tanks are overfilled the pressure would blow either the Sack or tank because the outlet is to small.
Q: Why "non return" valves?
A: other wise drainings the sacks would not work appropriaty
green is intake
purple is overflow
Electical:
This is pretty much straight forward if you use the original Cable Harness from MC for the Jabsco AI3 (pump timer box) ask Brian or Carly if you are not sure. I think the harness I got will also work for other Boats than the X45.
The great thing about the harness is that the cables fits perfect in length from the Battery Main Switch to the AI ( I placed it in the STBD Boot at the same place the orig. AI3 is placed on the PORT side) and to the Dash and Ballast Puppys.
So everything looks 100% original (is close to 100% original)
Just connect the harness with the main battery switch panel and "ground" (Plug is included) and to the AI3.
Connect the 3 ballast puppys with the harness and the AI3 (I recommend to soft-solder this connection, as the ballast puppys are not shipped with a corresponding connector - or you order the puppys orig, by MC)
Connect the part of harness for the toggle switches with the AI3.
Then connect the toggle switches with the harness.
The harness has a connector that you have to cut off to get the switches connected. Check the Jabcao technical data sheet how to connect: http://www.jabsco.com/files/itemdoc158771.pdf
I also provieded as schema how the toggle switch workes / should be connected. Bridge 12V for the LED (see picture above with AI3 connetors)
Very simple. dont get confused by the lot of connects the switch is carring ... You just need 5 of the 8.
Switch mounting:
I used a stainless steek plate, which I custom ordered (shaping, hole drilling, painting, engraving).
To get the shape I cuted template from paper.
The best place is the empty place down left at the Dash (see picture)
Cutting the Dash is easy - no problem, drill and cut.
Thats it!
It took me 1.5 Days to get it done (if you have everything you need in place)
Have a look how deep the platform is under water (the factory ballast is not even filled) and the sacks filled in the Boot:
Have fun and enjoy the ride!
Cheers Captain Fronk
Appendix
Part Listing:
Mastercraft original:
1 AI3: Jabsco control box: Part Nr.500760
(wiring info check:http://www.jabsco.com/products/marin...5877/index.htm - Technical Data Sheet) just bridge 12V for "fill /
drain" to LED (see also switch schema picture above)
1 Waterintake: Part Nr. 1 300273
3 Thru Hull Fitting - Chrome Part Nr. 3 301010
3 Toggle Switches: Part Nr. 502260
1 Harness (Cables) : Part Nr. 500591
1 set Fly High Pro X Series Mastercraft X-Star Additional Ballast Bags : http://www.wakemakers.com/fly-high-m...bags-only.html
35ft - 1" Ballast Hose Black: http://www.wakemakers.com/mastercraft-ballast-hose.html
50 - Stainless Steel Hose Clamp : http://www.wakemakers.com/1-inch-hose-clamp.html
3 1" Non-Return Check Valve Fitting : http://www.wakemakers.com/check-valv...ng-1-inch.html
1 1" Hose Barb Tee Fitting : http://www.wakemakers.com/1-inch-hose-barb-tee.html
2 1" Nylon Hose Elbows, Barbed : http://www.westmarine.com/webapp/wcs...<br /> <br />
1 Multi-Die Ratcheting Crimper Kit : http://www.westmarine.com/webapp/wcs...<br /> <br />
3 Double Male/Female Adapter : http://www.westmarine.com/webapp/wcs...classNum=10613
20 Fully Insulated Nylon Disconnects (for toggle Switches) : http://www.westmarine.com/webapp/wcs...assNum=10613=-
Local:
1 2mm Stainless Steel Plate (Dashplate for Switches)
3 ft cable 0.75 or similar
Stainless steel screws (for fixing pumps, AI3, Switch dash ...)
Cable straps
electrical tape
heat shrink tube
Tool listing
1 jig saw
1 cordless screwdriver
1 high temp hairdryer
1 Set Srewdrivers
1 knife
1 Wire cutter
regular toolbox content .. in any case
History:
Lets start
Pumps:
Plumbing:
green is intake
purple is overflow
Electical:
Switch mounting:
Thats it!
Appendix
Part Listing:
Local:
Cable straps
electrical tape
heat shrink tube
Tool listing
1 jig saw
1 Set Srewdrivers
1 knife
1 Wire cutter
