Originally posted by GT500 MC
View Post
X-14/X-14v owners & enthusiasts thread
Originally posted by rtw_travel View PostWe're keeping the tower clean for now. We have the stereo upgrade so the sound in the cockpit is excellent, but I didn't want to disturb the neighbours or have the kids disturb the neighbours with tower speakers.Prior boats - (3) X14's, (3) Prostars, and a Tristar.
One note for other X-14V owners - I've had two 14V's now, and both had ski pylons that were hard to install. I could not actually install the new one.
But I found the trick on my last boat and I used the same trick with the new boat. My problem was that the ring around the pylon on the floor was not exactly lined up with the pylon receiver under the floor. It is a 15 minute job to remove the ring, set it in the right place, drill new holes, and reinstall.
So if your X14V has a stiff pylon, the easiest thing to do is take the trim ring off on the floor (6 phillips screws), and see if the pylon is still hard to insert with no ring there. You may be surprized at how easy it really is.
You can see in the picture that I have removed all screws and centred the trim ring around the pylon. Then I put one screw into the one hole I could see, and drilled 7 new holes for the remainder of the screws.
...and yes, I used vegetable oil as a lubricant because its biodegradeable, but the oil is not really required if the ring is lined up properly.
Hope that helps someone.2014 X-14V
2012 X-14V (gone)
Originally posted by rtw_travel View PostOne note for other X-14V owners - I've had two 14V's now, and both had ski pylons that were hard to install. I could not actually install the new one.
Easier to take out in the morning when it's cooler too.
Originally posted by JohnE View PostThe 14 DD was a big hit in it's first few years. Then when the 14V came out in '09 that was a big hit. Clearly the numbers of each dwindled enough to drop them both. I'm a little surprised, I thought the 14V would be around a little while longer. The demise of the 14 DD actually made sense to me given the new prostar, which has way more room than the 197, along with the dwindling sales of the 14DD in it's final few years.
I'm super bummed they stopped the X-14DD. I thought it was one of the coolest designs they had... direct drive with wrap around seating. Best of both worlds. You can weigh down the back with fat sacks if you want to wake board or surf, but you can't undo the engine in the back if you want to ski...
Originally posted by double_shumba View Postthe new prostar is bigger, with more room... but it has fewer seats than the old one. I would think anyone going for the x-14DD would be looking for more seats (I am). Isn't a bigger ski boat with fewer seats just a ski boat that fits the same number of people with a bigger wake?
Originally posted by 93Prostar190 View PostNot an X14 ... but his slalom inspired brother ... the PS214 ....
Originally posted by GT500 MC View PostThat is odd---interesting quality issue. I had that exact same situation right from the dealer. Had them look at it during the initial service and they re-drilled the same way you speak of. Still a little tight but I tend to just keep the pylon in for the season anyway.
Damn it I want a X14 D.D so bad!!!98 Cobra - Custom Engine - Foxlake Racing - Accufab Racing - Holley Dominator ECU - Racepak IQ3 - Griggs Racing - Vortech - Kooks - Weldon - T56 Magnum - Built Rear End - HRE's - Baer - C&R - E-85
2013 F-250 PSD - Carli 2.5" Back Country - Fox Racing - BMF - Toyo RT's - Air Ride - AMP Research - Magnaflow - H&S - No Limit Fabrication - Deleted - Tuned - 450rwhp/1000rwtq
