So as I was putting the boat up for the weekend, I noticed a little more water in the bilge than normal... ugh. The amount should have kicked on the auto bilge pump I would think but did not. I didn’t think to turn the switch to manual first, I instead pulled the plug to drain instead. As I’ve been working on the fuel sending unit issue, I’ve noticed some water accumulation towards the stern (by tank/rudder area). Next time at the lake, I’m going to make sure the bilge is dry (probably use my wet vac). A couple of questions:
1. Does the bilge pump have a float, or will I most likely need to replace the entire pump?
2. In the past I’ve read about people pumping more grease into rudder seal, or shaft packing/drip less shafts. Do either of these apply to x-14, or what to check/look for?
3. Best way/place to trouble shoot water leaking in while on lake? Can I do it from lift with boat in water, or do I need to be moving, etc?
Thanks in advance!
X-14/X-14v owners & enthusiasts thread
Was there a post on the lenco part # for the center tab actuator , my 2010 c-14v needs one and its on my lift and hard to read
Leave a comment:
I've pulled barefooters with mine and it was in that 42 range. I recorded from my boat a barefooter in a 190 beside me and he left me. OJ told me there's a different prop that will add a few mph and reduce rpm at ski speed. There's likely a prop option for the rtp that would do the same.
I'm gonna say 75 mph will be hard unless another boat pulls you up on plane then let's you go 😂
Leave a comment:
Originally posted by TDOT View PostLooking at my last post it looks like I am trying to sell my boat to some redneck who wants a speed boat... Now although I cannot confirm or deny his redneckedness… He is looking to barefoot the boat and is looking to pull 41-43mph.
With that said we run 43-44 with the MCX, there is a video of DoubleD barefooting it here ....
https://www.youtube.com/watch?v=U0FI4Au8mX8 (phenomenal boat driving btw)
The RTP may be a little less than the MCX .... but I would expect 39-41
Barefooters like the shape of the wake I have been told.
Leave a comment:
Leave a comment:
Leave a comment:
Anyone know the top speed of a 08 x14dd RTP-1 Stock prop? I have a potential buyer asking... I just might need to get it out and do a test run.
Leave a comment:
Well played David ... the photographer on that pic had some good training!
Leave a comment:
Originally posted by 93Prostar190 View PostI have seen that on other models as well ... maybe to zipper up an extension to the front of it for increased coverage?
Just a guess ..... please pardon if it is an awful one
Speaking of awful .... DoubleD has not bought a beer yet today! or posted a new LED pic .... c'mon DoubleDawg!
Okay, whatever...
Leave a comment:
Originally posted by BAdair View PostSo we used our bimini for the first time since buying the boat and I noticed two zippers across the front. Anyone know what they are for? I'll try and snap a picture next time it's open but hopefully someone has some insight.
Checking my build sheet it says my boat came with:
Boat Cover w/ TWR
Bimini Cover w/ TWR
Cockpit Cover w/ TWR
Tonneau Cover
All I got with the boat was a standard boat cover and Bimini with a cover sleeve.
Leave a comment:
Leave a comment:
Leave a comment:
Originally posted by 93Prostar190 View PostHeck, if the price is reasonable I would buy one as well.
Yours always showing full may be a different issue ... too me the short length means it drops from full too quickly,
Did I misunderstand? Does yours always show full? That would indicate something else ?
Sent from my iPhone using Tapatalk Pro
Leave a comment:
Leave a comment:
