Mindbender you are close, some thoughts
I could not imagine surfing without at least 1 ballast bag. I don't know anyone that surfs without some ballast bags. Buy at least one 600-750lb bag and put it in the back rear of the side you surf. You will not believe the difference
This will list the boat just slightly which will raise your mission on the other side up some. Weight = push in the back corner.
Speed will then work out to around 10.6-11.4
As far as the mission, I mount mine just like JP-OH on back rear corner, down low, and tab forward, right underneath the tank overflow.
Having the tab forward protects the suction cup handles from water getting underneath them and mine never pops off.
Hope that helps
Hope that helps
