Water in driver foot well (X10)
  • Water in driver foot well (X10)
    This season I had a little water start tricking from behind the kick panel in front of the drivers seat. It felt warm so I closed the heater circuit valve near the riser on the starboard side of the engine (LTR)
    I still have water coming from behind the panel and it is no longer warm. How could water still circulate into the heater core with the valve being closed?
    Anyone else had this problem? Was it a hose, fitting, or the core itself?
    Thanks for any input!
    If you only have a valve on one end. then that is where the water is coming from. it could be back pressureing in. you need a valve on both ends.
    "Let me not pray to be sheltered from dangers, but to be fearless when facing them."
    1999 X-star, 330 LTR, Zero FLex tower.
      When I had a leak there, it was a split heater core.
      I pulled both hoses and barbed them together while I got the core replaced
      _________________
      2000 SD prostar 205
        Thanks. Where did you find a new core?
          I think you can get them at NAPA auto parts.
          Previous: 1993 Prostar 205
          FAQ
          Be kind. Have fun.
            Wow. That would be nice!
              The return line for the heater is typically tee'd into the raw water pickup line, so you're probably getting water straight from t he lake back flowing into the heater.
              '06 X2 MCX
                Yes - I wound up taking the old one to Advance Auto here and the counter guy found the closest match. The best fit I found had the hoses slightly off center - had to cut up the case a bit, but only minor surgery.
                _________________
                2000 SD prostar 205
                  I got mine from Napa also when Mine was bad.
                  Like stated above take it out of the heater box and carry it with you. they have a huge selection listed on there computer.
