Hi all.. I checked out a Maristar 225 VRS that is near our place a couple of days ago.. Here's a link to the listing:
There are a few things that concern me about this boat and I wanted to get some opinions.
Ballast system: The current owner installed a wake makers ballast system that has an 800 lb ballast on either side of the engine and a 400 lb ballast under the floor. Each of these has an inlet in the bottom of the boat.. three 1" holes were drilled for these. Is this typical for ballast install? Two holes are located near the engine and one near the drain plug. The installation does look good but I'm thinking that if one of those inlets somehow fails, the boat sinks.
Tower: There are some stress cracks in the gelcoat around where the tower is connected.. A friend of mine took a pic of this I can post soon... Do you guys think it wasn't attached properly? Does the fiberglass need to be reinforced somehow?
Trailer: The CO said the surge brakes were locking up in reverse so he somehow disabled them by welding something.. This sounds like a bad plan to me..
What is the life expectancy of an LT-1 engine? It currently has ~515 hours on it.
The boat is in pretty great condition.. The vinyl is original and looks like it will probably start to tear around the seams soon... But otherwise everything is nice.
Anyway, I'm thinking about offering ~$11-12k, $16k seems high to me.. What do you think?
Thanks!
Mike
Thanks!
Mike
