My ZeroOff is still NOT working at all in RPM Mode. After the first run it only shows "Pull up" and never kicks in again. When disconnecting the GPS Sensor (full power off), fallback to PerfectPass occurs and RPM is working just fine.
When editing profile speeds huge numbers come up (only in metric mode not in english units) See here
Still can't believe nobody else is having this problem, since all canada is metric, because I tried two other 2012 boats and the both had the same problem.
Also what I've heard from a lot of owners is that if the people actually building the boat hear a boat is going to europe or overseas they don't care at all and just throw everything in there. I would bet my a** that my boat has never been.... taadaaa: "lake tested"
I've had this happen in the beginning too, turns out the cruise was always thinking we're not going fast enough for surfing with the original surf profile, so it was keeping all tabs down trying to get us up to speed ("on plane"). Actually I recall it putting the tabs down every 20 sec or so.
Solved it with setting up my own surf profiles.
Who will assure you that the Murphy system is working better, Mastercraft won't, tey'll stick to their legal stuff...
Originally posted by FourFourty
View Post
Originally posted by bjames
View Post
