I have a 2005 X2 and the TPS sensor has gone out. I have contacted 2 different MC Dealers and have been told that the TPS sensor and/or the throttle control assembly MC part# 450119 are no longer available. Is there a replacement part or a retrofit design available? I have basically been told good luck with my problem and that no MC dealer will be able to help me because the part has been discontinued. This is extremely frustrating because the boat has only 500 hours and I’m being told there is no fix. Do I just abandon the boat?
2005 X2 Tps
I have been searching. I tried the BEI sensor replacement (which are very hard to find) and still have the same issue. I found the first BEI sensor in ebay so figured I would buy another from Mouser (found on a post) when I called them today the part is on back order until April.
I cant find a complete assembly (Teleflex CH2200E) either...
Does anyone know if this is an infrared contact or not?Aric
LONE STAR MASTERBASH 2022
Register Here
2019 XT22 - Ear Bleeder
2022 Sea Hunt BX22 CC
For Sale:
2020 Crest 240 SLC Tri Toon
Part is supposed to be low failure -
Talk to Larry
Larry Engelbert
Indmar Customer Service
Indmar Products
5400 Old Millington Rd.
Millington, TN 38053
Office: (901) 353-9930
[email protected]
Also check with Rambo Marine, Bakes online
Did you try Rambo Marine? Action Water Sports as for Bruce, bakes have the throttle part http://www.bakesonline.com/detail.aspx?ID=2337 but I could be wrong.
That's 2 parts causing problems now --- grrr -sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Originally posted by liledgy View PostGood luck with your search! I think I'll keep my 85 SS.CUSTOM WHEEL & TIRE PACKAGES
sigpic
Email - [email protected]
Originally posted by snork View Postsimilar if not the same I'd be on the phone with Indmar
electronics humidity, water, grime - not good -
but I would go the route of rebuilding the controller not replacing the whole thing if possible like the fuel pump 101 thread.
a couple of threads here on this.
http://www.mastercraft.com/teamtalk/...ad.php?t=56678sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Originally posted by Prostar19 View PostThere is not a lot MC can do if the part was discontinued by the manufacture. Remember the engine is not made by MC so and boat with an Indmar would have this same problem. I would try to contact Indmar.
I realize MC switched engine manufacturers, but if they want to keep loyal customers past about 3 years, they need to provide sufficient support for their somewhat recent power plants. I feel confident that they will. So please don't consider this a bash. Rather, consider me a voice that says he is confident MC will do the right thing.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Originally posted by mikeg205 View PostPart is supposed to be low failure -
Talk to Larry
Larry Engelbert
Indmar Products
[email protected]
Also check with Rambo Marine, Bakes Larry Engelbert
Originally posted by scott023 View PostThis is most likely your best route. Good luck.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
