Originally posted by j.robinson389
View Post
What Mastercraft is for me?
Originally posted by Jeff d View PostUmmm... Don't you own a MariStar 215 + a tower + ballast system + x series graphics?
The 205v is the quintessential wakeboard hull. It would also probably ski a little better than the MariStar hulls. That flat bottom won't handle rough water as well though. If you're in a large lake where storms tend to kick up this might be a little bit of an issue.
The Maristar hulls of that generation have more depth to them and should handle rough water better (Although still not what most would consider a "rough water" boat). They're more of a hybrid between the hull you'd typically see on an I/O runabout and a competition inboard hull. The 210/225/230/X-30 are more of a U shaped bottom than a V though. If surfing is your game I'd think a Maristar hull would do a bit better than a comparably weighted 205V.
Unless you're a borderline pro I'd be a lot more concerned with the condition and price of the boats than picking a particular hull and trying to buy that particular boat while ignoring others. The Maristar 210/225/230 all throw perfectly acceptable wakeboard wakes with ballast and can be had within your budget.
Originally posted by Jeff d View PostThe 205v is the quintessential wakeboard hull. It would also probably ski a little better than the MariStar hulls. That flat bottom won't handle rough water as well though. If you're in a large lake where storms tend to kick up this might be a little bit of an issue.
I didn't read your post, but a 96 205 would be perfect for you.
/Just kidding. I did read your post, and a 96 205 would be perfect. Of course, if you can find a 205V in your price range, that'd be even better considering your wants. But the regular 2nd Gen 205 will do it all fine with only a slight difference in seating arrangement.Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Originally posted by east tx skier View PostI didn't read your post, but a 96 205 would be perfect for you.
Listen. Lolsigpic
2014 Chap 264 Sunesta
2019 XT25 GEN2 5500
2015 X20 SS GEN2 6.0
2016 G21 Coastal 5.3
2014 X46 GEN2 7.4
2014 X30 GEN2 5.7
2006 VRS200 SS 5.7
2013 X30 GEN2 6.2
2013 Yamaha 242LS
I used to ski behind a '97 Maristar 200 and then behind an early 2000's 205V.
To me it is pretty much a toss up as far as skiing. The Maristar's wake was probably actually smaller, however a bit harder. The hull has a pretty good V near the front yet is flatter near the back of the hull than the 205V.
They were pretty similar for wakeboarding as well. The Maristar had a nice rounded wake vs. the 205's a little steeper (can probably tweak with fat sac locations).
On thing I did notice is the Maristar is not very good for tracking if you ever plan on skiing through a slalom course. The skier can really pull the boat side to side because the hull is so flat in places. One positive is that the boat can take tight corners because the back end slides while turning.
I'd let looks, prices, and shape make the determination rather than worrying about how they will ski. I'd get something with the motor in the middle if skiiability is truly an important factor (slalom at least).
Originally posted by east tx skier View Posta 96 205 would be perfect for you.
Also, It's small enough to store in a large garage, launch on pretty much any ramp etc but big enough to have a few people on board with kit and not be tripping over on everything
Here it is. There is so much money in this thing, it makes me sick.
