Hi Jim. I didn't get to work at the boat on Saturday as planned but finished up in work early today to get to the garage.
I run the checks you suggested and I've discovered that the return voltage (green wire) at the MAP sensor is reading between 2.6 and 2.9 VDC at idle. The plot thickens.
The voltages from the plug all check good when the ignition is on (but not started).
I'm waiting on the MAP sensor arriving that Mike got me a part number for but perhaps there is more to it than this. In your experience, is it common for the MAP to fail and deliver a high reading or is this scenario synonymous with vacuum leak?
I've encountered scenarios were an ECM will substitute a fixed voltage if the MAP fails but perhaps I can rule this out given the variation between 2.6 and 2.9 reading??
Thanks in advance for any input. It's greatly appreciated.
Stevie
Stevie
