2005 X45 LQ9 Heater Connection at Engine
  • 2005 X45 LQ9 Heater Connection at Engine
    I am installing a heater in my 2005 X45 with the Cadillac LQ9. Does anyone have pictures of where to connect the heater valves to the engine? It is a closed cooling system. Any recommended valves or where to purchase?
    I want to get the boat out early this year
    Thanks for the help.
    2005 X45 LQ9
    Atlanta, GA
    Anyone with an LQ9 and a heater?
    Thanks.
    David
      I have one. Let me do some investigating.
        Here is what it looks like. The larger hose goes to her heat exchanger and the two smaller ones go back to the heater core.
          More for some reasons I can only do one at a time.
            Number 3.
              And the last one.
                Brilliant . That is where I thought to connect the heater hoses, but I wanted to be sure. Do you know which is the inlet and which is the outlet for the waterpump? (My Maradyne heater recommends the flow to be in a particular direction).
                Thanks again for the help.
                David
                  After some investigation of the LQ9 and for information - the water pump fitting closest to the engine block (toward the bow of boat) is flow from the engine; the water pump fitting toward the stern is for the coolant return from the heater.
                  David
