can some one guide me through the steps of refinishing my teak platform?
Refinishing teak?
A lot of people here use 75% linseed oil 25% mineral spirits. Please understand that rags wet with linseed oil will self-ignite so don't leave a pile in your garage.
I used Watco teak oil the last time and I will not use it again, it leaves a gummy residue. The star brite teak oil may be better/different.Bailey
'02 X-9
Lake Blue Ridge
Originally posted by agarabaghi View PostIs this the sealer? http://www.acehardware.com/product/i...uctId=12818292
Originally posted by CruisinGA View PostA lot of people here use 75% linseed oil 25% mineral spirits. Please understand that rags wet with linseed oil will self-ignite so don't leave a pile in your garage.
I used Watco teak oil the last time and I will not use it again, it leaves a gummy residue. The star brite teak oil may be better/different.2003 ProStar 197, MCX and Powerslot.
Taxation = Theft
Originally posted by agarabaghi View Posthmm
So i still need a sealer?2003 ProStar 197, MCX and Powerslot.
Taxation = Theft
Teak
What I did the past week was power washed then let it dry. Sanded it with 150 to 220 sandpaper, Rinsed it off & let it dry again. Are used a tach cloth to remove any residue. Then I applied linseed oil and mineral spirits at a 75/25 or 80/20 ratio. I waited 24 hours between coats used three coats let try in sun.
Like others have said be careful with the rags - linseed oil is highly flammable. Dispose of properly.
The attached looks really thorough. I must admit I go for a less scientific approach. Stainless steel wire wool (gets into all the nooks and crannies that sandpaper can't) wash down then 2 or 3 coats of teak oil. I don't want the surface too smooth.
If you use sealer and no sand off you will get a painted look. I did this to mine and I think it takes less maintenance over time.. to get a rich look I would use a good teak oil.sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
