Originally posted by waterlogged882
View Post
Engine cover strut help
Originally posted by mikeg205 View PostYes they should work... just confirm length
One set is small and it just holds the fiberglass engine cover up and the other set holds the lower thing covered in carpet and the fiberglass thing.
I just need the smaller struts.
It says “spring lift gas springs” Atwood Texas SL-31-30 then 278/98 M
Which is the part number? I can’t find either99 Mastercraft Sportstar
Originally posted by waterlogged882 View PostThe first is a part number.
Fully extend the unit and measure it from center of eye to center of eye. Measure the fully exposed piston rod.
post back.
.99 Mastercraft Sportstar
Here is a link to click on. I venture to say this or similar will meet your needs. Click around on Scamazon and find your specific application. Your getting warmer. You need something in the range of 30 - 40 lbs. capacity.
Also C-C:
Originally posted by waterlogged882 View PostThat may suffice, however if you can find a little stronger capacity, I think that would be the way to go, just to be on the safe side.
Qty (2) 10mm Nylon End Lift Supports 7.5" Extended x 30lbs Struts Gas https://www.amazon.com/dp/B00K2FVYNA..._tHC4Cb480J8E5
The screen shot I posted says they have 3/8 ball type socket ends.. what i just linked too says 10mm. Will that work?
Thanks for your help man99 Mastercraft Sportstar
I use a small blade screwdriver to remove the locking caps.
Does anyone have a picture of where the engine box struts are placed on a 1999 ProStar 205? I have a 2 piece box, and two struts on the back hinges. There are at least 2 on the side, but I can't figure out where they attach: to the top cover or bottom piece?)
Originally posted by wjsully99 View PostDoes anyone have a picture of where the engine box struts are placed on a 1999 ProStar 205? I have a 2 piece box, and two struts on the back hinges. There are at least 2 on the side, but I can't figure out where they attach: to the top cover or bottom piece?)99 Mastercraft Sportstar
