Yep. I just got the boat but we're located around coastal waters so mostly salt. Great to surf in but it hammers boats. I just want to do my best to help her live long and comfortable. Fresh rinsing, polishing etc. Keep on top things as best i can. Hence looking for experienced advice on what others do.
What is this and how best to fix up
Originally posted by CantRepeat View PostPersonally, I wouldn't do anything but keep them sprayed down with WD40.
Are you still boating in salt?
If your mcocd kicks in, wire brush, sand, prep and paint with good paint or a rust converter like por 15.
I would also undo and anti seize every bolt you could. Looks like the whole bilge will be rusted together in a couple years based on how much corrosion now only 2 years old.
Edit beat me to it. Too many helpful people NOT boating today dammit....
Heading out now though!'06 X2 MCX
clean it up and spray it down with corrosion inhibitor.. maybe throw in some zinc anodes in the bilge and have them take the brunt of the corrosion..
salt water tuff.. I would get to that coupler - though - no reason to be stranded for what that costs to replace...sigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
If you wanna prep before painting/coating, Loctite Naval Jelly Rust Dissolver will eat the rust right off. Paint or coat immediately thereafter. http://m.loctiteproducts.com/browse_products.pl/7/24
+3 for the MCOCD approach. We don't see that much corrosion in 15 years here.
Naval Jelly, wire brush, sand, paint, anti-seize all other bolts. Fluid Film or Corrosion X regularly thereafter.
How does one flush saltwater ballasts other than fresh water fill or two?
Certainly explains the two replacement ballast pumps that have been done in two years. Previous owner did lots of wakeboarding (425hrs in two years) so i guess lots of carry in salt water by wet riders equals plenty of salt water accumulating in bilge. Probably the odd fat sac leak as well. Just seems to be on the mounts and the coupler.
So I'm heariing:
- degrease
- clean loose rust with wire brush
- bit of sanding to smooth out
- hit with a rust converter (best one?)
- throw some blue paint on
- cover with fluid film or corrosion X
- flush bilge with fresh regularly
Hows this sound?2013 X-25 SS (all black with 6.2) sold
