Buddy who has a X46 came out and claimed the X10 wave was as if not taller and longer than his boat. Stock X10 surf setup with 3 passengers aboard. Surf's up in the Rockies.
I think the X10 is a home run all the way around. I am biased obviously, but 3 season with my 2013 and still have not had that moment where I say "I wish it would do this better".
completely agree ...i wish i had gen 2 but other than that its absolutely perfect
First attempts at spins. Take it easy, point being stock X10 wave with two passengers is pushing around a big noob. Will punch up vid and hopefully surfing later.
I am having the same issue as the second one you show, about 25% of the time my front digs in when I come around, more weight on the back foot, or do I need to be higher up on the wave?
I can finally add to this thread. Had my wife take a video when I was setting up the wake last weekend. I will try and get some side shots next weekend. I wish the channel we were in were a little deeper. I think the depth finder was showing 19-20 foot depth.
I have swapped the 400lb rear bags with 750lb and installed a bow sac under the front seats that is piggy backed off the front KGB adding an additional 650lbs. I think I'm only getting about 550-600lbs out of it just because of the space limitations. Surf tab at 90% with no center tab @ 11.7mph.
I have also swapped the prop to an OJ #845. The prop is a stump puller and the only way to move this much weight IMO.
In the video I have full ballast along with 5 passengers including my self.
