Any good suggestions for MC steering wheels?
  • Any good suggestions for MC steering wheels?
    thinking of upgrading the look of my 08 X30. I have the 4 spoke "leather" wrapped wheel but thinking of a new wheel. Any thoughts? Doesn't have to be a MC wheel but then again, I've read that there's an issue with changing out the steering wheel - splined? hub? not sure what it all entails. I'd obviously prefer a plug and play setup. TIA!
    08 X30 - deader than dead...and crispy.
    Would love to know as well.
    Check Out Morrison Lake Ski Club On
    https://www.facebook.com/morrisonlakeskiclub/?fref=tsFacebook
      If you guys find and buy one, I would be interested in buying your old one for the ProStar.
        I'm interested in this also.
          Gussi makes some very nice steering wheels that will look good on a MC. They used to be OEM on MC, but I don't know if that is the case anymore.
            Thanks. I saw one I liked that was on ebay but it was already sold and I can't find it again.
              Mines a 2006 - I decided to go with the newer MC wheel -
              Somewhat frustratingly the diameter of the bolt patter is different on the new wheel - but rather than get a whole new hub, I just added one of these - http://www.ebay.co.uk/itm/Steering-w...AAAOSw9N1VrfZq
              There are apparently 2 main patterns - 70 & 74mm and annoyingly the 2 wheels are different - I can't remember which way around.
              Not a cheap option though - $540 for the wheel & cover kit
              The web's best place to buy OEM MasterCraft boat, Ilmor and Indmar engine parts and Accessories. This site's intended for private owners only. No dealers please
                That is the wheel I really want. So we just need the hub adapter, and nothing else to do with the spline issue, correct? price is a bit high but then again, it IS a Mastercraft...
                  Correct - it just has a slightly different PCD and that little adapter was all I needed.
                  I could have replaced the entire hub for a new one, but as you say, that is a spline fixing & I didn't know where it would lead next, so I went with the cheap adapter & it does the job perfectly. The wheel is about ½" further from the dash, but you can't even tell.
                  It did meant that I couldn't use the bolts that came with the wheel as the adapter has a narrower thread, but works just fine.
                    Did you need new bolts?
                      I drilled out the counterbore in the adapter to accommodate the heads from the bolts on the old wheel - that mounted the adapter onto the hub.
                      I needed new bolts for the new wheel into the adapter - I think they were M5 or M6, but will depend on the adapter you buy.
                      The other option would be to drill & tap the adapter to take the bolts that come with the new wheel, but it was easier for me to source new bolts.
                        Thanks!
