I'm in the market to buy a pressure washer to clean my aluminum dock and concrete driveway. I'm looking at gas powered, but not sure how powerful a washer I need. I would also need to run a really long hose from my house to my dock if I need to pull water from a house water faucet. Can I draw water from the lake for the pressure washer?
Pressure Washer for Dock
Originally posted by stuartmcnair View PostDon't buy one. Rent one with a drum scrubber. A commercial unit with a scrubber would cost around $1500. You can rent one for a weekend for around $150. When you factor in maintenance and parts you come off much better doing it that way.
I am the odd ball- Bought one used that had a Honda motor. I have had it about 14 years and my in laws use it as well. Wash the house/decks/cars/boats/snowmobiles/camper. We did have to replace the pump last year and that was about $90. Maybe mine is small but it blew all the lettering off the camper when I wanted to replace that! If I have it to narrow of stream it will tear up the wood on the deck.......
No I would not run lake water in the pump!!
Originally posted by Rocketboy View PostI am the odd ball- Bought one used that had a Honda motor. I have had it about 14 years and my in laws use it as well. Wash the house/decks/cars/boats/snowmobiles/camper. We did have to replace the pump last year and that was about $90. Maybe mine is small but it blew all the lettering off the camper when I wanted to replace that! If I have it to narrow of stream it will tear up the wood on the deck.......
No I would not run lake water in the pump!!“You realize your odds of winning the lottery are the same as being mauled by a polar bear and a regular bear in the same day”….E-Trade Baby.
Just did the research and purchased one last year. First, based on a driveway tool, you need a minimum of 3000 psi. I had a smaller (2400) psi one that worked OK, but my 3100 psi one is much better with that attachment.
Generac was rated highest. I bought a Honda engine one with idle down. works great and was $300. A better choice would have been $600+.
Don't waste your time with electric ones.1997 PS 205
mine is a Craftsman 2900 or 3000 psi, had it for 8-9 years, use highest octane pump gas with stabilizer mixed in. It usually cranks on 3-4 pull after sitting all winter. I think I paid ~$250-300. Just used it at my daughter's house to remove algae/moss from sidewalk, patio, driveway and cleaned exterior brick & garage doors. Worked like a charm. I wouldn't use lake water either personally.
Originally posted by maxpower220 View PostJust did the research and purchased one last year. First, based on a driveway tool, you need a minimum of 3000 psi. I had a smaller (2400) psi one that worked OK, but my 3100 psi one is much better with that attachment.
Originally posted by 73blue View PostThats funny, because I could never see myself buying a gas-powered PW again. I have an electric that we use literally every day from May to September. Use it for everything from concrete, to wood decks, to aluminum pontoons, to boat interiors. Dont have to worry about fuel or really any maintenance. And no pullcord. Pull the trigger and it fires up, let off and it shuts off.
Originally posted by 73blue View PostThats funny, because I could never see myself buying a gas-powered PW again. I have an electric that we use literally every day from May to September. Use it for everything from concrete, to wood decks, to aluminum pontoons, to boat interiors. Dont have to worry about fuel or really any maintenance. And no pullcord. Pull the trigger and it fires up, let off and it shuts off.Prior boats - (3) X14's, (3) Prostars, and a Tristar.
Just hire me, I do that for a living ... http://www.mrwindowfla.comNEW SKINS ...
Jim - "Upholstery Guy"
(865) 995 0607 Hm (BSURE 2 LVMSGE)
(865) 679 2246 Cph (ANYTM UPTO 9PM EST)
[email protected]
sigpic
I've got badass '93 MC BF 200 w/ a Yahamie ProV 200.
M O S T A W E S O M E C R A F T E V E R B U I L T
'Luv'n life behind a Barefoot 200'
atlfootr
Originally posted by Maristar210 View PostWhich one did you buy? I'm in the same boat as you, don't want a gas, don't need 3000 psi either.Originally posted by JohnE View PostWhat make and model?
http://www.homedepot.com/p/Ryobi-170...4122/203800590
